POV-Ray : Newsgroups : povray.documentation.inbuilt : Issues with sor tutorial example. : Re: Issues with sor tutorial example. Server Time
20 Jul 2026 21:20:04 EDT (-0400)
Date: 3 Nov 2025 03:21:48
Message: <6908661c$1@news.povray.org>
On 11/2/25 14:08, Kenneth wrote:
Thanks for confirming on windows.
> So I wonder if the problem is just shadow artifacts: sturm on/off has the
> opposite effect on the inside and outside-- and on the lighted surface vs.
> shadowed surface(!)
I agree. The bad sturm results for official are shadow related.
However, I believe this due the sturm results, sometimes, not being that
accurate - by position. Specifically, I'd bet here on a 'quicker exit'
bug in the regula-falsi code - fixed in yuqk - which finishes off the
root calculation once an interval with a single root has been found by
the sturmian portion of 'sturm'(*).
> The appearance of the noise and the artifacts on the*outside* depends on the
> the camera position, its look_at point, the position of the light(s) and the
> orientation of the SOR-- all of which interact, unfortunately. It looks the
> worst to me  when the y-positions of all three are the same (and not just when
> the camera is looking straight into +z).
> Since the SOR when 'open' is really just an infinitely thin shell, it seems to
> me that using it this way is not a good idea anyway, as  the walls have no
> thickness at all and look unrealistic. (The docs also mention that it shouldn't
> be used in CSG this way.)
No... :-) The sor{}s are more like cylinders/cones in having well
defined inside regions always with two surfaces when using caps and,
potentially, only a single surface - with the same, well defined, inside
region - depending on the ray path when not using caps.
In playing more with the sor{} shape recently, I've come to think it
more useful due potential use in CSG! The sor{} doesn't have the fuzzy
issues with defining an inside regions which Cousin Ricky highlighted
recently for the lathe{} at fold-backs, for example.
Bill P.
(*) - I have more sturmian solver work years now on the todo list;
Including replacing the regula-falsi code with a dedicated
newton-raphson solver I wrote from scratch that always resolves to the
root once given an interval known to have a root. That work though is
tangled in also wanting to remove a re-ordering of coefficients into the
sturmian part of 'sturm' that I suspect was long ago done for
convenience, but which burns time.
I have too another solver approach which, for accuracy is much better
than 'sturm'. However, it requires even more re-working of code because
it merges the per shape polynomial generation and solver into one
method. Maybe someday...
