On 12/22/2016 5:26 AM, dick balaska wrote:
> Am 2016-12-21 03:29, also sprach Jaime Vives Piqueres:
>> El 21/12/16 a las 05:22, clipka escribió:
>>> Do you know of any possible reason for entering animation when both
>>> initial and final frames are equal but neither 0 nor 1?
>> It makes sense when you're using the clock to obtain a series of
>> different stills. I remember with my Tierra project, I used to let an
>> animation rendering overnight with different, random parameters for each
>> frame. Then at the next day I would check them all and re-render at
>> better quality only the good-looking ones.
>> jaime
> But if initial and final are equal, what would the clock be?
> final - initial = 0; which is not a good clock divisor.
> I do final = 10; and then +SF2 +EF2 to do single frames.
Jaime might be using "clock" as a synonym for animation.
I use frame subsets for animations and testing values too. I prefer
using integers to fractional numbers in my calculations. It makes more
sense to me as you can't render a frame that is not a whole number.
Regards
