POV-Ray : Newsgroups : povray.documentation.inbuilt : Searching the Help file. : Re: Searching the Help file. Server Time
13 Nov 2025 01:13:29 EST (-0500)
Date: 13 Feb 2016 20:43:03
Message: <56bfdba7@news.povray.org>
On 2/13/2016 1:02 PM, Jim Holsenback wrote:
> On 2/8/2016 9:33 PM, Jim Holsenback wrote:
> createSubIndex.php scans the files in directory tagged (these files are
> un-post processed windows docs pulled from wiki) and writes to directory
> indexed. the .txt files are the break outs. of special interest ...
> progress.txt as you can see there are > 1500 tags that need to be
> converted in the wiki mark-up
several more things ...
- unpack the archive preserving directory structure. work in
subject-index. i've "grouped" the tag types. create-SubIndex has some
hints (comments in the code) and so do the .txt filenames that i used.
- i figured if i could filter, i could convert them to a landing spot
from the index. the simpler (and some of the compound) tag forms have
been done. sans the conversion to a landing place.
- compound tags are a single landing place for more than one topic from
the index
- i've discovered some of the compound tags (in the mark-up) are
malformed, that is they aren't formatted correctly, or their intent is
not clear. some of the more complex tags can be made simpler without
sacrificing intent. finding them and cleaning them up (on the wiki) is
the biggest task.
- once the mark-up has been fixed and all tags types can be parsed
correctly. it's easy enough to reformat into a landing place.
... i'm sure there's more
