"SharkD" <mik### [at] gmail com> wrote in message
news:4aff7f0c$1@news.povray.org...
> I'm using 3.6.1.
> The index entries for most of the transform keywords point only to the
> quickref. They should point to better locations with actual text
> descriptions. Separate links to the quickref are OK, as long as they are
> nested underneath the main links in the index.
Thanks for all your hard work, however your post is a bit lacking ....
I'm back writing the code to pull this stuff back out of the wiki and I
don't have time to go digging. If you would create a talk page (not the
entire page ... just the section(s)) were you've spotted the above mentioned
that would be immensely helpful.
Jim
BTW: Your post about "Operators" was equally confusing .... if you wouldn't
mind following up in kind, I'd appreciate it!
