POV-Ray : Newsgroups : povray.bugreports : inside() results in: Parse Error: Expected 'operand', object identifier, found instead : Re: inside() results in: Parse Error: Expected 'operand', object identifier= Server Time
17 Nov 2025 01:23:28 EST (-0500)
Date: 28 May 2025 10:25:00
Message: <web.68371ba64583c609cefaa2a925979125@news.povray.org>
Lars Rohwedder <rok### [at] gmxde> wrote:
> I tried some magic with inside() and isosurface, but povray does not
> like even the simplest terms involving the inside() function,
inside () never got implemented in the function virtual machine, so:
Use an object pigment pattern in your function instead:
function {
     pigment{
          object{
               MyObject
               rgb 0 // outside
               rgb 1 // inside
Then the result of your "inside" test will be the rgb value.
- BE
