Running 3.7.1-beta.2
;POV-Ray Initialization file (render settings)
;Run this file in POV-Ray to obtain the rendered image
;NOTE: Delete the command line options in the toolbar
; before pressing RUN to use the settings in this file
;This file has been created by PoseRay v3.13.23.587
;3D model to POV-Ray/Moray Converter.
;Author: FlyerX
;Email: fly### [at] yahoo com
;Web: https://sites.google.com/site/poseray/
;Files needed to run the POV-Ray scene:
;Satellite_POV_main.ini (initialization file - open this to render)
;Satellite_POV_scene.pov (scene setup of cameras, lights and geometry)
;Satellite_POV_geom.inc (geometry)
;Satellite_POV_mat.inc (materials)
;Input POV-Ray file
Input_File_Name="Satellite_POV_scene.pov"
;Output rendered image file
Output_File_Name="uss_assy_2017_06_13_12_18_11.png"
;Resolution
+W320
+H238
;Output format: PNG (portable network graphics)
+FN
Bits_Per_Color=16
;Antialiasing
-A
;Quality
+Q9
;Alpha transparency option
-UA
;Continuation option
+C
version=3.7
Preset INI file is 'C:\Users\Tech
Desk\Documents\POV-Ray\v3.7-beta\ini\quickres.ini', section is '[1024x768, AA
0.3]'.
Preset source file is 'C:\Users\Tech
Desk\Documents\POV-Ray\v3.7\poseray_install_3_13_23\Satellite\Satellite_POV_main.ini'.
"C:\Users\Tech
Desk\Documents\POV-Ray\v3.7\poseray_install_3_13_23\Satellite\Satellite_POV_main.ini"
line 31: Unknown switch 'A' in INI file.
"C:\Users\Tech
line 31: Cannot continue to process INI file 'C:\Users\Tech
due to a parse error in line 31.
This is not a valid INI file. Check the file for syntax errors, correct them,
and try again!
Valid options in INI files are explained in detail in the reference part of the
documentation.
Failed to start render: Failed to parse INI file
