"jmichae3" <jmi### [at] yahoo com> wrote:
> another problem. after 1 successful run of pvengine.exe, can no longer run
> pvengine.exe, even with a reboot.
> "[Microsoft Windows]
> POV-Ray for Windows v3.7 has stopped working
> A problem caused the program to stop woring correctly.
> Please close the program.
> [->Close the program]"
> and this is the same bug I see when I run good programs compiled with gcc lately
> (iostream/fstream bugs?)
As I already mentioned, POV-Ray for Windows is compiled with Visual C, not gcc!
However, did it occur to you that if other programs are malfuctioning on your
computer that the source of the problems will be your computer and not a sudden
defect of several programs you are running? -- Your computer is broken and you
need to get it fixed, or better yet, replaced.
Nobody will be able to help you if different programs on your computer crash.
The programs are fine. This is not a bug in any of those programs, it is a
problem with your computer!
Given this is the fourth bogus message in a row
*plonk*
<https://en.m.wikipedia.org/wiki/Plonk_(Usenet)>
