POV-Ray : Newsgroups : povray.bugreports : 3.7 doesn't run on vista 32-bit, no source code available to build : Re: 3.7 doesn't run on vista 32-bit, no source code available to build Server Time
18 May 2026 02:10:10 EDT (-0400)
Date: 9 Sep 2016 09:40:00
Message: <web.57d2bb4bf87a5c8c944c3db40@news.povray.org>
> Am 09.09.2016 um 05:20 schrieb jmichae3:
> > as it turns out, shortcut points to wrong exe. shounld not be the sse version,
> > just 32.
> No, the SSE2 version should run fine on your machine; but the installer
> incorrectly links to `pvengine-sse2.exe`, when in fact the executable is
> named `pvengine32-sse2.exe`.
> It's a known issue, with a known workaround, but a fixed installer
> hasn't been released so far.
I could not find that section of code in github. could not find the installer
source.
why not make that change right now?
btw, submitted a minidump, it was bacause of clicking close [X] on upper right
corner of povray 3.7, causes a crash.
got 3.7 to run by double-clicking pvengine32. pvengine32-sse2 causes a minidump
on AMD athlon x2 64.
