Le_Forgeron <lef### [at] free fr> wrote:
> Le 08/09/2016 à 11:08, jmichae3 a écrit :
> > 3.7 doesn't run on vista 32-bit, no source code available to build.
> > the program is GPL'd, which means it is open source and if a binary is given,
> > the source code must be made available. but I cannot find the sources.
> The program is GPL, but the Editor for Windows is a totally different
> license.
> The GPL sources are on github.
> > my platform is vista 32 on an amd athlon x2 "64" which really seems to act like
> > a 32-bit processor with PAE (address extensions), given they way it can allocate
> > 64GB+/disk of virtual memory just like that, whereas XP32 was limited to
> > 4GB/disk.
> > fixed virtual memory does not alleviate the need for more RAM, but it helps.
> > auto-allocated virtual memory always fails to work.
> This problem should have been reported in povray.windows, IMHO.
thanks.
[Problem with Shortcut]"The item the pvengine-sse2.ee that this shortcut refers
to has been changed or moved, so this shortcut will no longer work properly. Do
you wwant to make this shortcut?" [yes][no]
