POV-Ray : Newsgroups : povray.bugreports : #write : Re: #write Server Time
8 Jun 2026 13:53:22 EDT (-0400)
  Re: #write
Date: 2 Mar 2016 18:20:00
Message: <web.56d7742ea95e761bfd6b6fe10@news.povray.org>
> Am 01.03.2016 um 23:08 schrieb Le_Forgeron:
> > ab-using code like
> > #write( .... #write( ...
> > is a call for lightning from Zeus and the opening of the multidimensional portal
for Chtulhu.
> Actually - no. There's no abuse in there /per se/. The nested `#write`
> might be part of a macro invocation, such as in:
> #write(File,SomeMacro())
That sounds like a break in scoping rules.  It's not like the code is just
dropped inline as it is with c macros, though that's how it works with the
result.
Sounds like we need a proper function system in the new language.  Assuming it
ever takes shape.
but if you think that's bad, take a look at this little Gem, I found a few days
ago.
while ( --argc > - && (*++argv)[0] == '-' )
  for ( s = argv[0]+1; *s; s++ )
    switch( *s )
      default:
        usage ( progname );
        exit ( -1 );
        break;
Typing it out makes me want to go scrub my hands with steel wool.
A.D.B.
> where `SomeMacro` might be part of a 3rd party include file that itself
> makes heavy use of file operations, e.g. to persist some random number
> generator's state across frames or the like.
> Most notably, `Parse_String` is implemented as a macro that uses `#write`.
