Warp <war### [at] tag povray org> wrote:
> Thorsten Froehlich <nomail@nomail> wrote:
> > The place where it is used is the core part of the tokenizer. Using a
> > dynamically allocated string would significantly increase overhead in the most
> > called place as the short string optimization won't work (it is frequently not
> > more than 10/14 chars). Now consider the average POV token length, and you
> > notice
> > you get at least one additional memory allocation per token parsed.
> Does the part that parses tokens really need to use the exact same string
> class as the part that parses and handles strings?
No, and actually, checking the code, this part of the tokenizer uses the unbound
string parsing. Which leaves the question how the original poster could get this
error message. The problem most likely is an identifier longer than 255
characters ... which is, well, really pointless to have.
