POV-Ray : Newsgroups : povray.bugreports : Parse Error: String too long. : Re: Parse Error: String too long. Server Time
10 Jul 2026 06:53:28 EDT (-0400)
Date: 28 Dec 2014 14:50:00
Message: <web.54a05e13f7cf417b8694a3930@news.povray.org>
"jmichae3" <jmi### [at] yahoocom> wrote:
> Preset INI file is 'D:\WWW\JESUSNJIM\RAYTRACE\JOHN3_16-17.INI'.
> Preset source file is 'D:\WWW\JESUSNJIM\RAYTRACE\JOHN3_16-17.INI'.
> Rendering with 12 threads.
> Parser Options
>   Input file: John3_16-17.pov
>   Remove bounds........On
>   Split unions.........Off
>   Library paths:
>     C:\Users\Jim-Michaels\Documents\POV-Ray\v3.7\include
>     C:\Windows\Fonts
> Animation Options
>   Initial Frame:        1  Final Frame:     9104
>   Frame Step:           1
>   Initial Clock:    4.500  Final Clock:  -11.000
>   Cyclic Animation.....Off  Field render.........Off  Odd lines/frames.....Off
> Image Output Options
>   Image resolution.....720 by 405 (rows 1 to 405, columns 1 to 720).
>   Output file..........John3_16-170001.png, 24 bpp PNG
>   Dithering............Off
>   Graphic display......On  (gamma: 2.2)
>   Mosaic preview.......Off
>   Continued trace......Off
> Information Output Options
>   All Streams to console..........On
>   Debug Stream to console.........On
>   Fatal Stream to console.........On
>   Render Stream to console........On
>   Statistics Stream to console....On
>   Warning Stream to console.......On
> "John3_16-17.pov" line 136: Parse Error: String too long.
> Render failed
> CPU time used: kernel 0.06 seconds, user 0.00 seconds, total 0.06 seconds.
> Elapsed time 0.39 seconds.
> the string has 263 chars. why is this even a problem? if this is written in c++,
> use std::string in <string>. please fix.
in source/backend/parser/parse.h line 54,
const int MAX_STRING_LEN_FAST = 256;
// this needs to be usable as bit mask, so keep it MAX_STRING_LEN_FAST - 1
const int MAX_STRING_LEN_MASK = (MAX_STRING_LEN_FAST - 1);
is way too small. it should be 65536. I also see another set of strings in the
windows
config that looks a mite small. windows/pvtext.cpp
  char                  str [2048] ;
several of those.
