On 2023-12-18 11:16 (-4), William F Pokorny wrote:
> While continuing to think about yuqk / v4.0 texturing clean up /
> changes, I took a detailed look at cutaway_textures.
> I'm pretty sure the 0110 difference case below should end up as 'Red
> Red'. The nullptr result for the pigment I see as a bug itself in any
> case - the pigment should end up set to something valid.
> The behavior is identical v3.7-stable, v3.8 beta 2 and yuqk on linux.
> Do windows users see the same bug?
I'm also using GNU/Linux, but for what it's worth, case 0110 halts in
POV-Ray 3.5 and 3.6 with the message "Rendering Error: No textures in
multi-texture CSG object."
