> As an example, we once(*) had a report on these newsgroups of POV-Ray
> producing strange stray white pixels in the output image; after some
> research, it turned out that this guy had apparently been operating his
> CPU (also some AMD, btw) without adequate cooling, and while the CPU
> appeared to still be fine to do other things, it did fail sporadically
> but frequently while executing POV-Ray, littering the output with ramdom
> white pixels. Replacing the CPU solved the issue. (*Until the same
> person burned out the replacement CPU as well.)
Yep... that was me. :) And yes, the CPUs where AMD Athlon X2 in both
cases.
jaime
