POV-Ray : Newsgroups : povray.bugreports : #write : Re: #write Server Time
8 Jun 2026 13:52:03 EDT (-0400)
  Re: #write
Date: 2 Mar 2016 05:17:37
Message: <56d6bdc1@news.povray.org>
Le 02/03/2016 08:25, clipka a écrit :
> Am 01.03.2016 um 23:08 schrieb Le_Forgeron:
>> The heap is exhausted
> I presume you mean "stack", right?
yes... and I was tired also, because it's 4 functions calls per
iteration, not 2, so the stack size would need a x10...
>> NAAAAHHH, Parse_Write should use a pattern already use elsewhere, no more than one
recursion... or even none at all.
> That would plug up only one of a guesstimated 4711 ways to coax the
> POV-Ray parser into recursive calls.
> Wanna bet that "#write" does the very same thing?
> I think it would be more sensible to impose some arbitrary upper limit
> to the nesting of Get_Token() calls; that would at least catch one
> entire family of those 4711 ways.
Beware to not stop code that stacks #local and other in the middle of
valid statement, including themself. limiting to #write (and #read) at
least have a smaller impact.
OTOH, I never was fan of "smart" code.
