POV-Ray : Newsgroups : povray.bugreports : relative path in Output_File_Name : Re: relative path in Output_File_Name Server Time
17 Jul 2026 10:35:06 EDT (-0400)
Date: 28 Apr 2011 14:29:25
Message: <4db9b205$1@news.povray.org>
Le 28/04/2011 15:22, Bastien Jacquet nous fit lire :
> I was using the following path in POV 3.6 without any problem, but it does not
> work with 3.7 saying :
> IO Restrictions prohibit write access to 'rendered_seq\mirror001.png'
> Render failed
> Output_File_Name="rendered_seq/mirror.png"
> Am I doing something wrong ?
> Is it a working directory related problem ?
> Bastien Jacquet
Have you read :
> http://wiki.povray.org/content/Documentation:Windows_Section_2.1#I.2FO_Restrictions
Please report your OS.
1. you are not doing anything wrong, it blocks you as intended.
2. If you did not grant more permissions (see url), you have write
access to the current directory, but not anything below.
> http://wiki.povray.org/content/Documentation:Unix_Section_4#I.2FO_Restrictions
For Unix, you need wildcard to grand subdirectories
(as "read+write*=." instead of "read+write=." )
