POV-Ray : Newsgroups : povray.binaries.utilities : Wood design program test version Server Time
27 Sep 2024 05:27:06 EDT (-0400)
  Wood design program test version (Message 10 to 19 of 39)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Wood design program test version
Date: 28 Jun 2022 09:55:00
Message: <web.62bb06d94b788a98d7f62f03aa81652d@news.povray.org>
"..._angular_distortion_(0, 1, 2).inc"
connects the angular shape. The more characteristic heights you set, the more
files are produced.
Then
"..._angular_shape_factor.inc"
assemble them.
"..._radial_speed".
The files above is no need to change, if you have thoughts about them, you
should tell me. Because using program to generate these data is more convenient
than DIY.
"..._time_and_ring"
This file composite the radial speed, angular shape distortion,(and knot shape
distortion in the future) to a single function "time_function(x,y,z)", it input
position, output 'age at that position', but in fact :P, its output is zero at
the tree base <0,0,0>, and get bigger when you keep away from the (tree)center.
The Unit is year.
Here it produce two additional function 'pinstripes' and 'wood band', these two
functions output value 0~1, 0 represent early-wood, 1 represent late-wood(dark
part).
Download 'files of data output.png' (130 KB)
Preview of image 'files of data output.png'
Date: 28 Jun 2022 10:15:00
Message: <web.62bb0be14b788a98d7f62f03aa81652d@news.povray.org>
"tree_colormap_temp_file.inc" is the place I composite (all) patterns, ... to
the output pigment.
I directly copy this file from ...which made by myself.
Output pigment is named 'diffuse_pigment'. It has rgb colors. In the future it
is necessary to produce grayscale output for the roughness map, normal map...,
too.
"..._bumps_pattern_detail.inc" prepares the thin pattern, fiber, ... for the
You can produce more thin pattern here, using the macro I write
generate_thin_circled_pattern_f_input_t_theta_h(
), I only finish this one(in fact two or three, but they appointed by this one)
for generate thin pattern.
You can use any function produced by yourself.
You can change these files above.
Download 'files of the output.png' (141 KB)
Preview of image 'files of the output.png'
Message: <web.62bb0cd04b788a98d7f62f03aa81652d@news.povray.org>
"Mr" <m******r******at_hotmail_dot_fr> wrote:
> this looks like it's going to be a fun tool !
> Thank you very much indeed. I am truly impressed. As Maurice said: this
> is going to be fun to play with. I shall let you know my thoughts while
> testing this.
> Thomas
Thanks two... 'fun' . ..
Date: 1 Jul 2022 08:30:00
Message: <web.62bee7694b788a98f50b25a7aa81652d@news.povray.org>
The 'macro' which I should introduce is
first_time, last_time, d_boundary_time0, d_boundary_time1, t_radial_bump_size,
time_node_amount,
bump_size_along_theta, theta_pos_random_factor,
min_h, max_h, d_boundary_h0, d_boundary_h1,
seed_m,
r_vs_t, h_vs_r_ratio
It is located at bump_pattern_base_function_macros.inc
The goal of it is to generate thin pattern, just like f_bumps(x,y,z).
But it is on the different coordinate system(I say that 'tree log coordinate' in
this case), this macro just generate an output_f = function(time, theta, h) {
It generate bumps along theta by generating an position array[seg_amount] during
0~2*pi, it consult the input 'bump_size_along_theta' to determine the
seg_amount, the shorter the bump size, the larger the seg_amount.
'theta_pos_random_factor' controls the randomize of the positions. When it is
zero, the position is equally spaced on theta, when it is 1, the position has
the max randomize.
Download 'generate pattern macro var_theta.png' (38 KB)
Preview of image 'generate pattern macro var_theta.png'
Date: 1 Jul 2022 08:55:00
Message: <web.62beed364b788a98f50b25a7aa81652d@news.povray.org>
'first_time', 'last_time', 'd_boundary_time0', 'd_boundary_time1' define the
boundaries of the pattern on 'time value', you can regarded it as the radial
direct pattern.
't_radial_bump_size' as in attachment picture, unit is year.
'time_node_amount' is because, if it generate only one continuous pattern on
theta, the 'bump_size_along_theta' cannot maintain, the bump_size will get
smaller at the smaller radius. So I generate several patterns. On different
radius, I apply different seg_amount to theta position array[seg_amount]
It is the origin of it needing 'time_node_amount' to determine the amount of
such pattern on different radius. You can set it 3~5 it should sufficient.
Download 'generate pattern macro var_t.png' (38 KB)
Preview of image 'generate pattern macro var_t.png'
Date: 1 Jul 2022 09:15:00
Message: <web.62bef1f04b788a98f50b25a7aa81652d@news.povray.org>
Such design is assumed the ideal situation. In fact, I'm planning to revise it.
It is obvious imperfect along the h-direct, When I ..'veneer' it, it shows no
change pattern (along theta).
Download 'show board2 radiosity.png' (1035 KB)
Preview of image 'show board2 radiosity.png'
Date: 3 Jul 2022 03:35:00
Message: <web.62c145db4b788a98f10dbcecaa81652d@news.povray.org>
The Java version which I used is Java SE 8 (1.8.0_91) currently. So the version
above it should be acceptable.
Date: 4 Jul 2022 08:06:39
Message: <62c2d7cf$1@news.povray.org>
Op 27-6-2022 om 17:56 schreef And:
> First release.
Thanks And!
Test version, so I shall not (yet) comment on the visual aspects and so on.
However, one very important thing is the way decimals are written to the
example include files. My system uses 'dots' (example: 3.9432) instead
of 'commas' (example: 3,9432) like is done by your app. I guess that
some countries/systems do so standard, but not all. My system uses
'dots'. If this is an issue for better international use, could you make
this an initial choice to make by the user? Or is there another way to
change this easily?
Date: 4 Jul 2022 12:30:00
Message: <web.62c314a84b788a98f10dbcecaa81652d@news.povray.org>
> > First release.
> Thanks And!
Thanks for understanding.
I use 'meter' as the length unit, so that output result is caused by my habit.
The dots are decimal points.
I want to ask a question, a number contain commas can be read as 'one' number
correct by POV-Ray?
Can 3,9432 be a number?
> change this easily?
> Thomas
Currently You might need use 'scale' to the pigment to convert it to your
customary unit. I will add a list(menu) to select unit on the "Basic
Profile"(first page) in the future version. But I need time to research this.
Date: 4 Jul 2022 12:50:00
Message: <web.62c3191f4b788a98f10dbcecaa81652d@news.povray.org>
Excuse me, I upload the same version but compress to the .zip
Download 'wooddesignprogram alpha ver20220627.zip' (987 KB)
