POV-Ray : Newsgroups : povray.binaries.programming : povr render 'optics.pov' Server Time
23 Nov 2024 07:16:18 EST (-0500)
  povr render 'optics.pov' (Message 1 to 7 of 7)
Subject: povr render 'optics.pov'
Date: 15 Aug 2020 11:25:00
Message: <web.5f37fd6ba57451a94d00143e0@news.povray.org>
hi,
an unrelated thread made me render the 'scenes/advanced/optics.pov' file.  with
'povr' I get a strange "band" in the lower part of the image.  attached.
regards, jr.
Download 'povroptics.png' (210 KB)
Preview of image 'povroptics.png'
Subject: Re: povr render 'optics.pov'
Date: 15 Aug 2020 11:52:30
Message: <5f3804be@news.povray.org>
Le 15/08/2020 à 17:21, jr a écrit :
> hi,
> regards, jr.
Only for povr, at least hgpovray38 is clear of such noise, and so I
presume official master (3.8) too.
Date: 15 Aug 2020 12:15:00
Message: <web.5f3808df37c3ceb74d00143e0@news.povray.org>
hi,
yes, the alpha.10064268 output is ok.  have not yet installed 'bigarade' on this
machine, so good to know, thanks.
regards, jr.
Date: 15 Aug 2020 12:35:10
Message: <5f380ebe$1@news.povray.org>
On 8/15/20 11:21 AM, jr wrote:
> hi,
Thanks jr (and Jerome)!
I see it too in all my recent povr versions. It was OK in versions early
this year, so something I've done between then and early July.
I'll do a binary search - compile/run through my commits to find the
commit causing the problem. FYI. No photons required to see it.
(jr, If you are looking for a scene with a parabolic mirror I recall
Warp doing one some years ago which he posted. I thought had a copy
somewhere, but I cannot find it at the moment. He might have used a
polynomial for the shape.)
Bill P.
Date: 15 Aug 2020 13:30:00
Message: <web.5f381ac537c3ceb74d00143e0@news.povray.org>
hi,
no sweat.  :-)
that should probably be addressed to 'ttyUSB0'.  I was simply curious, following
Le Forgeron's reply to him/her.
regards, jr.
Date: 15 Aug 2020 14:16:43
Message: <5f38268b$1@news.povray.org>
I broke the checker pattern on March 29th. ;-)
There has been a defined EPSILON value floating around in the code for a
long time. Over the years it sort of got used any time folks had the
thought, "I need an epsilon value." All to often it was (at 1e-10) a
non-optimal value to use.
I've been cleaning these up; mostly breaking them into two buckets after
determining what I thought good values numerically while doing my solver
work. A treat this as zero epsilon and a good supportable intersection
depth tolerance. The former I called gkDBL_epsilon which is a little
larger than the C++ DBL_epsilon macro value and the other is called
gkMinIsectDepthReturned(1).
When I updated EPSILON in the checker pattern, I used gkDBL_epsilon when
I should've used gkMinIsectDepthReturned. Yes, this is an intersection
with a plane, low order and more accurate - it was mostly working
anyway. The actual supportable value is certainly between the two values
I settled on. But, going with the standard gkMinIsectDepthReturned in
checker unless something 'else' breaks.
Aside: Yes, sometimes you really need somewhat unique 'epsilon' values.
When I was cleaning up the tiling patterns for isosurface use, I ran
across a collection of such values where someone had commented that a
C++ macro should perhaps be used. But in testing each, every one of
those needed to be what they were to the order of magnitude. Jerome had
done his homework! :-)
Anyway, thanks again for spotting this / testing.
Bill P.
Date: 15 Aug 2020 15:00:00
Message: <web.5f38301837c3ceb74d00143e0@news.povray.org>
hi,
> When I updated EPSILON ...  it was mostly working anyway. ...
anytime.  (while I can, 'povr' permitting.  ;-))
regards, jr.
