Subject: An updated povr tarball for Unix/Linux. 0883e2b6
Date: 2 Apr 2023 13:30:42
Message: <6429bbc2@news.povray.org>
Please see the attached tarball and previous announcements in this fora
and INSTALL.txt for suggestions on compiling and running via wrapper script.
A reminder the povr fork is not POV-Ray. As time passes, it's less
likely existing POV-Ray scenes will work without modification.
Bill P.
--------------------- povr-3.8.0-x.povr_0883e2b6.tar.gz April 02, 2023
povr R7 v0.6.1.0
Found the povr fork picked up Christoph's late 2018 and early 2019
text{} block cmap{} keyword code changes intended to enable support of
more true type font (.ttf) files. The functionality looks useful in
testing and - though not planned - the povr fork will keep the work. See
the keyword documentation for more information.
Removed the 'hf_gray_16' and 'hf_grey_16' keywords. These have not
functioned since v3.6 and they only existed to generate a warning
message that they no longer worked. All v3.7 onward gray file output
control is accomplished with ini keywords or command line flags.
Updated RTR_HACK configuration so it can disabled by setting RTR_HACK to
0 at build / compilation. Disabling previously required a header file
edit to comment or remove the definition.
Adding the SDL functions word_is() and word_get(). These access and make
use of 18 internal arrays of token information relative to the active
version of POV-Ray(povr). The 18 arrays break down into three sets.
Namely. Previous tokens (back to through v3.6) which are out (o prefix);
Tokens included in the current code (i prefix); Lastly, tokens which are
new (n prefix) compared to the prior major release (v3.8 beta 2). See
documentation for more detail on use.
In debug compiles the internal function f_boom() now does a hard assert
rather than a handled throw to enable the creation of core dump files.
Changes to cone / cylinder base==apex error handling. Formerly a throw
was triggered - which did not generate a core dump file. Updates made so
in non-debug compiles the parser generates PossibleErrors and continues.
In debug compiles a hard assert condition is raised. This stops parsing
and enables the generation a core dump file.
Added configuration option POV_File_Text_INC_DEBUG. Set to 1 to get
include debug output as files are read. Default is 0.
Restoring v3.7 ifdef, ifndef and defined() ID only behavior.
The ripples and waves patterns largely re-written as they had a
significant number of issues. Not the least of which was depending upon
a global_settings{} number_of_waves keyword initialized in each thread
and not identically. See documentation and related newsgroup posts. The
frequency and phase collisions with internal pattern values should be
considered a part of the ripples and waves re-work and those issues were
previously fixed with ip_frequency and ip_phase.
Changes to make the height_field image handling more consistent. Indexed
images which have long produced a very weak height (for historical
reasons) are now illegal. Color image handling for <=8 and >8 bit depth
images is now all using the inbuilt, standard color to grey conversion.
In other words, the special red weighted, red+green gray conversion for
<=8 bit depths is gone.
Fixed color image_map out of bounds transparency so it no longer sets
the r,g and b channels to 1.0. Something which led to inconsistent
channel results depending on how information was accessed both within
the program and by users.
Allowing average keyword within map declarations alongside blend_map and
blend_gamma so predefined maps can be declared ahead of time for later
average pattern use. Without this change it was impossible to create a
map id for use with average. In other words, previously, everything had
to be defined within the entity using the average pattern.
Added a set of complex functions defined and documented in the include
file cfunctions.inc. The current list mostly follows that in c++11 on
and currently includes: cf_abs, cf_acos, cf_acosh, cf_add, cf_asin,
cf_asinh, cf_atan, cf_atanh, cf_cmplx, cf_conj, cf_cos, cf_cosh, cf_div,
cf_exp, cf_imag, cf_inv, cf_ln, cf_log, cf_mul, cf_neg, cf_norm,
cf_phase, cf_polar, cf_pow, cf_proj, cf_real, cf_sin, cf_sinh, cf_sqr,
cf_sqrt, cf_sub, cf_tan and cf_tanh
Added a new inbuilt scene and function vm keyword in log2 which wraps
the c++ std::log2. Note c++ log and log10 names are ln and log,
respectively, with POV-Ray. A reason to make log2 inbuilt is
performance. Along with floor and ceil, log2 can be reliably used to
detect numerical values having a power of two encoding.
Download 'povray-3.8.0-x.povr_0883e2b6.tar.gz' (1884 KB)
William F Pokorny <ano### [at] anonymousorg> wrote:
> Please see the attached tarball [...]
Thank you.
ingo
hi,
> povr R7 v0.6.1.0
my gcc is "elderly", and compilation fails, alas. excerpt from build:
Script started on Tue 04 Apr 2023 13:46:03 BST
POV-Ray (povr) 3.8.0-x.povr_0883e2b6 has been configured.
Built-in features:
I/O restrictions: enabled
X/SDL Window display: enabled (sdl not available)
Supported image formats: gif tga iff ppm pgm hdr png jpeg tiff openexr
Unsupported image formats: -
Compilation settings:
Build architecture: x86_64-slackware-linux-gnu
Built/Optimized for: x86_64-slackware-linux-gnu
Compiler vendor: gnu
Compiler version: g++ 5.5.0
Preprocessor flags (CPPFLAGS):
-pthread -I/usr/include/OpenEXR -I/usr/include
Compiler flags (CXXFLAGS):
-pipe -w -fno-enforce-eh-specs -std=c++11 -march=native -mtune=haswell
-ffast-math -O2 -fPIC -pthread
Linker flags (LDFLAGS):
-L/usr/lib
Libraries (LIBS):
-lXpm -lSM -lICE -lX11 -lIlmImf -lIlmImf -lImath -lHalf -lIex -lIexMath
-lIlmThread -pthread -lIlmThread -ltiff -ljpeg -lpng -lz -lrt -lm -pthread
-lpthread
The POV-Ray (povr) components will be installed in the following directories:
Program (executable): /home/jr/POVr/bin
System configuration files: /home/jr/POVr/etc/povray/3.8
User configuration files: /home/jr/.povray/3.8 (povr ignoring)
Standard include files: /home/jr/POVr/share/povray-3.8/include
Standard INI files: /home/jr/POVr/share/povray-3.8/ini
Standard demo scene files: /home/jr/POVr/share/povray-3.8/scenes
Documentation (text, HTML): /home/jr/POVr/share/doc/povray-3.8
Unix man page: /home/jr/POVr/man
See the file INSTALL.txt for more build options and information.
make all-recursive
make[1]: Entering directory '/tmp/POV/povray-3.8.0-x.povr_0883e2b6'
Making all in source
make[2]: Entering directory '/tmp/POV/povray-3.8.0-x.povr_0883e2b6/source'
CXX base/mathutil.o
CXX povms/povmsutil.o
CXX vm/fnintern.o
CXX vm/fnpovfpu.o
static_assert(sizeof(float) == 4); // These I think redundant for c++11
Makefile:1311: recipe for target 'vm/fnintern.o' failed
make[2]: *** [vm/fnintern.o] Error 1
(btw, is there an option to turn on _all_ compiler warnings ?)
regards, jr.
"jr" <cre### [at] gmailcom> wrote:
looks like the web ui didn't like the apostrophes supplied by compiler, trying
again:
> ...> CXX vm/fnintern.o
> CXX vm/fnpovfpu.o
vm/fnintern.cpp: In function 'double pov::fnEnc2x_f32(double, double)':
vm/fnintern.cpp:153:38:error: expected ',' before ')' token
regards, jr.
I'm using following set:
-pedantic -Wall -Wextra
YB
hi,
thanks, yes those too. there are (for gcc) various -Wxyz switches, I tend to
ask for shadow, format-security, strict-overflow, conversion, undef, and such.
(would have liked a single config option, rather than editing the build script
btw, every reply you post here is also sent to my inbox. Thunderbird "at work",
huh ?! ;-)
regards, jr.
> huh ?! ;-)
Sorry, it was default TB behaviour, I've turned it off.
YB
Subject: Re: An updated povr tarball for Unix/Linux. 0883e2b6
Date: 5 Apr 2023 04:53:05
Message: <642d36f1$1@news.povray.org>
Yep. I think having a compiler not compliant to c++11 is the only way
you can get that fail. I have in my head the configure program should
kick out a warning if it cannot do certain c++11 things - those might
not include the compile time asserts though.
Aside: All v3.8 releases, technically, require a c++11 compliant
compiler - but there is fuzziness to be had for sure.
There is a configure script flag called: --enable-compile-warn which
turns on a set of warnings (and turns off -w).
You can of course add more -wall -wextra come to mind as ones I run when
just trying to clean up things a little - but I cannot find those notes
at the moment...
Bill P.
hi,
> > my gcc is "elderly", and compilation fails, alas. ...
ok, thanks. built it on the VM, gcc 10, all good.
regards, jr.
Date: 6 Apr 2023 01:56:33
Message: <642e5f11$1@news.povray.org>
Good to hear - thanks.
Bill P.
