Hello.
Hopfully this is not very wrong group, as it seems to be only binary
group, which has relevance for this message ;-)
I have problem with UV-mapping: it seems to me, that it does not work
correctly on surface edges. I use Rhino for creating surfaces and then
export them to .3DS and from it with Win3DS2POV to Pov-Ray format.
Now, when I compare output from Rhino renderer and from PovRay, then it
could be seen, that on edges, where U and V have small values, texture
mapping is corrupted. I add 2 pictures to illustrate this problem. UV
values run in Rhino model from 0 (green-yellow corner) to 7 (red-blue
corner).
Is this known problem and/or is there workaround for it? I tested it
with UVPov 5.2. If it helps, then I can send test files for it (texture
map, 3DS file, PovRay files).
Download 'rho.jpg' (28 KB)
Download 'uvpov.jpg' (27 KB)
Preview of image 'rho.jpg'
Preview of image 'uvpov.jpg'
Someone else had a similar problem, but I was unable to find the problem
at that point. Hopefully I will this time. That person was also doing
a Rhino->3ds->POV conversion, so the problem may be in one of the steps
of the conversion process. But I won't rule out UV-Pov. I'd rather
you not email the files (limited disk space on the server holding my
email), but if you could post here or in the scene-files group, I'll
take a closer look.
-Nathan
Vahur Krouverk wrote:
> Hello.
> corner).
> [Image] [Image]
just download a new version of Win3dstopov at
http://extra.newsguy.com/~tbaier/
I have found a curious bug with UV-mapping conversion.
Very small values are destroyed.
>Hello.
>corner).
-tb
Thomas Baier wrote:
> Hi,
> -tb
Thank You! This new version corrected the problem. Other Thank You for
writing textures to different file from objects: it was not easy to edit
files with size 12M.
