POV-Ray : Newsgroups : povray.binaries.programming : Difference : Re: Difference Server Time
19 Jun 2025 11:51:26 EDT (-0400)
  Re: Difference
Date: 7 Dec 2005 12:39:21
Message: <43971e49$1@news.povray.org>
Hello Roman, Thanks for your quick response.
Maybe I was also too quick when I wrote the question.
The problem is the folowing:
Imagine that I have 2 boxes: 1 is red and the other is blue and they are
one ontop of the other. If I cut this with a Black box I obtain a black
edge. But i want the edge red and blue. It is not a problem of total
pigments or final pigments (or textures), the problem is that i want to
see the "real" cut of the first object. Maybe this is just fundamental
problem in Pov-ray because all objects are empty and you only see
surfaces. I was just wondering if anybody have had this problem and have
  solved it. Imagine that you have a Ham and Cheese Sandwich and u cut
it with a red knife. I don't want to see a red cut but the edge of the
bread, the ham and the cheese.
Alvaro
Roman Reiner wrote:
> First of all this is the wrong newsgroup. such questions should be posted in
> newusers http://news.povray.org/povray.newusers/
> To answer your question. When i understand you right you want the resulting
> object to have one overall texture. in this case it is the easiest way not
> to use pigments (or textures) in the single object declarations but apply
> it once to the resulting cutobject. for example
> difference {
>   object { this }
>   difference {
>     object { that }
>     merge {
>       object { whatever }
>   texture { myTexture }
> Hope that helped
> Regards Roman
> Alvaro Blanco <abl### [at] icmmcsices> wrote:
>>Hello all,
>>This is my first post and maybe I ask a silly (beginner) question: When
>>you use difference you get the color of the object you substract. When
>>you substract something easy, let's say, a box A minus a box B, then it
>>is easy to get the right color in your cut surface. You just use the
>>same color for B. But, when A is something composed of many different
>>objects with many different colors... Is there any way or "trick" to get
>>this colors in the cut edge instead of the same color of B?
>>Thanks
