POV-Ray : Newsgroups : povray.binaries.images : No color from image_map pigment Server Time
26 Sep 2024 23:36:10 EDT (-0400)
  No color from image_map pigment (Message 1 to 5 of 5)
Subject: No color from image_map pigment
Date: 24 Sep 2013 10:05:02
Message: <web.52419aebcf1f2a1b314aa6840@news.povray.org>
Hopefully this will be quick for someone...I'm banging my head against it and I
know it should be simple, but not quite getting it.
I'm texturing a box using a pigment gradient with two image maps as input. When
I render I don't get any color from the original images...what am I missing?
The attachment has the output on top and the original image maps on the bottom.
Here's the relevant code:
#declare White_Texture =
  image_map {
    jpeg "white_hq.jpg"
    map_type 0
    interpolate 2
#declare Red_Texture =
  image_map {
    jpeg "red_hq.jpg"
    map_type 0
    interpolate 2
box {
  <-12, -7, -0.1>, <12, 7, 0.1>
      pigment_pattern {
        gradient x
        pigment_map {
          [0.00 Red_Texture]
          [0.25 Red_Texture]
          [0.75 White_Texture]
          [1.00 White_Texture]
      translate <0.5, 0.5, 0>
      rotate 180*y
      scale <24, 14, 1>
    finish {
      ambient 1
      diffuse 0
Download 'nocolor.jpg' (225 KB)
Preview of image 'nocolor.jpg'
Subject: Re: No color from image_map pigment
Date: 24 Sep 2013 10:14:19
Message: <52419e3b@news.povray.org>
>    texture {
>      pigment {
>        pigment_pattern {
>          gradient x
>          pigment_map {
>            [0.00 Red_Texture]
>            [0.25 Red_Texture]
Try the above change, the pigment_map should be part of pigment, not
pigment_pattern...
Date: 24 Sep 2013 10:19:19
Message: <52419f67$1@news.povray.org>
Not immediately sure, but I /think/ it is because you use a
pigment_pattern which only reads black/white.
Have you tried this?
           gradient x
           pigment_map {
             [0.00 Red_Texture]
             [0.25 Red_Texture]
         rotate 180*y
         scale <24, 14, 1>
etc...
> pigment {
>    image_map {
>      jpeg "white_hq.jpg"
>      map_type 0
>      interpolate 2
> pigment {
>    image_map {
>      jpeg "red_hq.jpg"
>      map_type 0
>      interpolate 2
> box {
>    texture {
>      pigment {
>        pigment_pattern {
>          gradient x
>          pigment_map {
>            [0.00 Red_Texture]
>            [0.25 Red_Texture]
>        rotate 180*y
>        scale <24, 14, 1>
>      finish {
>        ambient 1
>        diffuse 0
Date: 24 Sep 2013 11:15:00
Message: <web.5241ac2da1609435314aa6840@news.povray.org>
You are correct, I just had to pull the pigment_pattern block out completely...I
knew it was something simple.
This works:
box {
      gradient x
      pigment_map {
        [0.00 Red_Texture]
        [0.25 Red_Texture]
      rotate 180*y
      scale <24, 14, 1>
    finish {
      ambient 1
      diffuse 0
Date: 24 Sep 2013 11:47:49
Message: <5241b425$1@news.povray.org>
pigment_pattern takes a full-colour pigment and returns a greyscale
pattern. It's useful if you want to use a pigment as a pattern.
For example if you wanted to use a defined pigment instead of "gradient
x" you can do this:
             // gradient x
             pigment_pattern { myPigment }
             pigment_map {
               [0.00 Red_Texture]
               [0.25 Red_Texture]
           rotate 180*y
           scale <24, 14, 1>
However note the pigment_map is not inside pigment_pattern, otherwise
the Red_Texture or White_Texture would get chosen inside
pigment_pattern, then converted to greyscale (as the OP code did).
