Same size from camera's perspective. Kirk
"Fabien Mosen" <fab### [at] skynetbe> wrote in message
news:3AB927E0.BC328B56@skynet.be...
Well yeah, but if you're projecting onto a plane (which we are) then you
gain the distortion. This is why fisheye doesn't get this distortion, as it
effectively projects onto a sphere (so the projected size corresponds to the
angle subtended at the camera, the size "from the camera's perspective").
Though I'm not 100% sure what a real camera does, probably somewhere
in-between as a consequence of the lens bending the light...
Tek
http://www.evilsuperbrain.com
Tekno Frannansa wrote:
> > > Same size from camera's perspective. Kirk> > Well yeah, but if you're projecting onto a plane (which we are) then you> gain the distortion. This is why fisheye doesn't get this distortion, as it> effectively projects onto a sphere (so the projected size corresponds to the> angle subtended at the camera, the size "from the camera's perspective").
Right.
> Though I'm not 100% sure what a real camera does, probably somewhere> in-between as a consequence of the lens bending the light...
A real camera is closer to ultra_wide_angle. The distortion happens,
but a little less than with a perfect plane projection.
Fabien.
