POV-Ray : Newsgroups : povray.binaries.images : Cylindrical pattern animation - how to get the circles/dots overlap : Re: Cylindrical pattern animation - how to get the circles/dots overlap Server Time
21 Jul 2026 10:10:48 EDT (-0400)
Date: 13 Jun 2026 08:00:00
Message: <web.6a2d459ca47dc4ffd1d09a9825979125@news.povray.org>
> Are you sure? If I replace them with actual color vectors, I get the
> error message "Parse Error: Expected 'operand', color
>   keyword 'rgb' found instead"!
Absolutely.
You are trying to shove a keyword and a vector into a scalar-only function that
gets parsed by the function VM.
> How can I use real colors instead?
Use a pigment_map. or a color_map.
In that case, you can even get rid of the select() statement.
The _maps do exactly that:  they map the output values of your function to
colors, pigments, textures, normals, or materials.
color_map {
  [ 0.0  rgb <0, 0, 0>]
  [ 0.5  rgb <0, 0, 0>]
  [ 0.5  rgb <1 ,1 ,1>]
  [ 1.0  rgb <1 ,1 ,1>]
Double entries at 0.5 give a hard transition.
Now any value below 0.5 will be black, and any value above 0.5 will be white.
- BE
