POV-Ray : Newsgroups : povray.binaries.images : RGB Rainbow Gradient : Re: RGB Rainbow Gradient Server Time
13 May 2026 00:28:14 EDT (-0400)
Date: 17 Mar 2026 01:30:00
Message: <web.69b8e5b6b7d0e03d17d879459334df62@news.povray.org>
"Leroy" <whe### [at] gmailcom> wrote:
> Very nice work!
>   If you want to get around the 3.7 color_map limit. Make an array of colors any
> size you want then cut the array into peaces that are under 3.7 limits. Make
> pigments with color_maps from those peaces with locations that match the
> original location values of a color_map with all the colors in it. Then make a
> pigment of all those pigments. Of course  All the pigment should use the same
> pattern!
Thank you Leroy, that's great advice!
Best regards,
Dave Blandston
