POV-Ray : Newsgroups : povray.binaries.images : RGB Rainbow Gradient : Re: RGB Rainbow Gradient Server Time
12 May 2026 23:28:19 EDT (-0400)
Date: 16 Mar 2026 19:15:00
Message: <web.69b88e93b7d0e03db9bd5883f712fc00@news.povray.org>
"Dave Blandston" <nomail@nomail> wrote:
> Greetings Folks,
> I'll share this here in case anyone ever finds it useful... The RGB rainbow
> gradient is useless for data visualization but it's still popular for artistic
> purposes. It has some limitations such as excessively bright points at the pure
> yellow, cyan, and purple points, visually unbalanced proportions of the base
> colors, and extreme differences in brightness values over the entire gradient
> with the blue area being most noticeably dim. Here's a version with non-linear
> transitions between the base colors that solves some of the problems. (The blue
> part is still dim compared to the rest of the colors.) It also introduces a new
> problem, which is that more transition points between the base colors are
> required. In my opinion, at least five transition points are necessary to
> achieve acceptable results. The maximum that POV-Ray 3.7 will allow is
> forty-three.
> Have an awesome day everyone!
> Kind regards,
> Dave Blandston
> * * * I hope this "copy-and-pastes" OK!
> #local NColorMapEntries = 7;
> #local ColorMapEntry = array [NColorMapEntries] {
>    <255, 0,   0  >, //0 Red
>    <255, 255, 0  >, //1 Yellow
>    <0,   255, 0  >, //2 Green
>    <0,   255, 255>, //3 Cyan
>    <0,   0,   255>, //4 Blue
>    <255, 0,   255>, //5 Purple
>    <255, 0,   0  >  //6 Red
> } //array
> #local NTransitionPoints = 43;
> #local RainbowGradient_NonLinear = texture {
>    pigment {
>       radial
>       color_map {
>          #for (I, 0, NColorMapEntries - 2)
>             #for (J, 0, NTransitionPoints - 2)
>                #local Ratio = J / (NTransitionPoints - 1); //0 .. 1
>                #switch (I)
>                   #case (0) //Red to yellow
>                      #local A = 270 + Ratio * 90; //Fast to slow
>                      #local Ratio = cos (radians (A)); //0 .. 1
>                   #break
>                   #case (1) //Yellow to green
>                      #local A = 180 + Ratio * 90; //Slow to fast
>                      #local Ratio = cos (radians (A)) + 1; //0 .. 1
>                   #break
>                   #case (2) //Green to cyan
>                   #break
>                   #case (3) //Cyan to blue
>                   #break
>                   #case (4) //Blue to purple
>                   #break
>                   #case (5) //Purple to red
>                   #break
>                #end //#switch
>                #local CurrentColor = ColorMapEntry [I] * (1 - Ratio) +
> ColorMapEntry [I + 1] * Ratio;
>                #local CurrentPoint = (I * NTransitionPoints + J) /
> ((NColorMapEntries - 1) * NTransitionPoints - 1);
>                [CurrentPoint color CurrentColor / 255]
>             #end //#for
>          #end //#for
>       } //color_map
>    } //pigment
>    rotate -90 * x
>    finish {emission .9}
> } //texture
Very nice work!
  If you want to get around the 3.7 color_map limit. Make an array of colors any
size you want then cut the array into peaces that are under 3.7 limits. Make
pigments with color_maps from those peaces with locations that match the
original location values of a color_map with all the colors in it. Then make a
pigment of all those pigments. Of course  All the pigment should use the same
pattern!
 I made a pigment with a 1000 colors as a test. I never did push the limit of
the number of colors. Now with 3.8 we wont need to :)
Have Fun!
