POV-Ray : Newsgroups : povray.binaries.images : Planet Mars : Re: Planet Mars Server Time
19 Nov 2025 05:22:50 EST (-0500)
  Re: Planet Mars
Date: 17 Oct 2025 14:10:00
Message: <web.68f285909d2be0d15ff18c9730225ff5@news.povray.org>
"Paul Bourke" <pau### [at] gmailcom> wrote:
> Which dataset are you using?
> These are from the MOLA 1/8 degree data
>     https://paulbourke.net/miscellaneous/mars/oneeight.html
> Can't remember the date but I had early access to the data.
In use at the moment 16000x8000 for the surface-map and 32000x16000 DEM.
That maybe sounds big, but its not big enough :)
There was once a NASA website - mapaplanet.org - where you could choose an area
on Mars, and only download a surface and a DEM map from that specific area.
Unfortunately also with limited resolution, but I would like to have something
like that in high-res.
I created this video of Mars at the time, I think with 2000x2000 pixel maps.
https://www.youtube.com/watch?v=0CAEoP-xg5U
If I could download this area with > 20000 pixels somewhere, then flying through
would be quite simple. It's not a question of povray-code or technology, just
data.
I searched several times for sources and tools, but never found what I needed.
Or the tools were so complicated that I couldn't find out if they were suitable.
ma
