POV-Ray : Newsgroups : povray.binaries.images : Object Placement Rabbit Hole : Re: Object Placement Rabbit Hole Server Time
18 Apr 2026 00:32:32 EDT (-0400)
Date: 19 Jul 2025 07:20:00
Message: <web.687b7e6acdb862487b8494536cde94f1@news.povray.org>
hi,
"Chris R" <car### [at] comcastnet> wrote:
> A scene I have been working on has a number of objects that lie randomly on an
> uneven surface.  I created some SDL code, customized to the objects in question
> to place them so that all points of the bottom surface of the object are on or
> above the corresponding points of the surface.  After getting the code to work
> fairly well, I went down a rabbit hole and decided to make it generic for all
> objects and surfaces and add the code to my libraries.
> The result of all of this is a dictionary representation of a transform that I
> have written, along with code for writing it to a file so you can generate all
> of the transforms before you start rendering the scene.  Depending on the size
> and complexity of your object and surface, and the level of detail, this can be
> time-consuming, so I ensure I can run it once, generate the transforms, and then
> just include them in the scene for rendering.
> The code needs a lot more testing before I put documentation and official
> examples into the GitHub repo with my libraries, but I thought I'd share the
> idea in case there are comments, (like "someone has already done this...") :-)
that does sound very nice and _useful_, I can think of two or three projects in
the past where I'd have liked having "supporting code" for planting (then
"vegetation") or placing objects.
> ... (in the XZ plane only) ...
I posted a usable quad-tree a few years back, fwiw.  no ref but will "dig it up"
if thought useful.
regards, jr.
