POV-Ray : Newsgroups : povray.binaries.images : Ring : Re: Ring Server Time
19 Nov 2025 06:31:42 EST (-0500)
  Re: Ring
Date: 17 Oct 2025 15:35:36
Message: <68f29a88$1@news.povray.org>
Le 2025-10-16 à 09:02, yesbird a écrit :
> On 16/10/2025 13:43, Alain Martel wrote:
>> It looks like your material have a rather high ambient value. That
>> make that gold look as if it was plastic. Try setting ambient 0.
> Thanks for suggestion, but it's already == 0:
> #declare F_metal  =
> finish {
>      reflection {0, 1 fresnel on }
>      conserve_energy
>      brilliance 5
>      ambient 0
>      diffuse .5
>      phong 5
>      phong_size 40
>      metallic
>      specular .4
>      roughness 1/20
>      reflection .5
> YB
Your diffuse seems to high for a metal. Normally, I use something less
than 0.1.
Fresnel reflection for a metal ? Fresnel is for objects that have an IOR
and are not metals. Useful when you want to simulate a varnish coat on a
metallic object using a layered texture. In that case, don't forget to add
interior{ior 1.6}// or something similar.
One base texture with the metallic texture, then, another transparent
texture with the fresnel reflection, followed by an interior block
giving the IOR of the varnish.
My suggestion :
#declare F_metal  =
finish {
     brilliance 5
     ambient 0
     diffuse .05 // Lower diffuse
     metallic
     specular .4
     roughness 1/20
     reflection {.5 metallic}
#declare Varnish =
material{
	texture{
		pigment{rgbt 1}
		finish{
			reflection{1 fresnel}
			phong 1
			phong_size 40
			fresnel
	interior{ior 1.55 dispersion 1.02}
Then, maybe it's the environment that is to bright... The appearance of
metals depend a lot on the environment.
