POV-Ray : Newsgroups : povray.binaries.images : A doodle and ramblings on pattern{} and iso perturbation : Re: A doodle and ramblings on pattern{} and iso perturbation Server Time
24 Jan 2026 03:59:51 EST (-0500)
Date: 6 Jun 2025 09:57:46
Message: <6842f3da$1@news.povray.org>
On 6/5/25 20:21, Kenneth wrote:
> warp{ turbulence .5, omega .001 }
It just popped into my head I forgot to add a comment on the code above
in my prior post.
What you've coded is OK for a result, but given the omega value is so
small all the steps (octaves) of the brownian motion are meaningless
after the first step (2nd step value is already down to 0.0005).
The octaves default is 6 and this means steps beyond 2 (the effective
minimum) are just burning CPU time. Coding instead:
warp { turbulence .5 octaves 2 omega .001 }
is about 24% faster in a quick test just now using overkill AA to better
seen the performance change against the total CPU bill for a complete
render. FWIW.
Bill P.
