POV-Ray : Newsgroups : povray.binaries.images : Other things the text object can do. : Re: Other things the text object can do. Server Time
18 Apr 2026 16:48:35 EDT (-0400)
Date: 19 Mar 2025 02:25:16
Message: <67da634c$1@news.povray.org>
On 3/4/25 10:35, William F Pokorny wrote:
> I started looking at a yuqk version of documentation for the text{} object.
Playing with the thickness parameter.
I've always specified values >0, but it works with values at 0 and with
negative values. With the latter though, by intent or mistake, only
renders the front and back surfaces - and the interior exterior
treatments are interesting / different(*).
Iideally we'd have an 'open' capability with text{}, but the way the
negative thickness values are working allows us to somewhat easily add
front and back surface textures which are different than the text{} sides.
The images use an 'interior_texture{}' that is green for the "What the
heck" string. Only matters with the negative thickness on the third and
fourth sub images. The fourth also using 'inverse'.
Bill P.
(*) Jerome contributed fixes to v3.8 which stabilized the interior /
exterior surface treatments for text{} objects with +z thicknesses. This
means prior versions will behave differently.
Download 'textthicknessstory.png' (85 KB)
Preview of image 'textthicknessstory.png'
