"JRG" <jrg### [at] hotmail com> wrote in message
news:3bbb71a9@news.povray.org...
> Just added a sphere to make things a bit more interesting. The effect is
far
> from being perfect, and you should notice some *errors*.
What errors ?
Scott Hill.
Software Engineer.
E-Mail : sco### [at] innocent com
Pandora's Box : http://www.pandora-software.com
*Everything in this message/post is purely IMHO and no-one-else's*
JRG wrote:
> Just added a sphere to make things a bit more interesting. The effect is far
> from being perfect, and you should notice some *errors*. The problem is that
> I can't find anything wrong in the algorithm, ya know, you look at the code,
> say "this must work", and yet something goes wrong... it's frustrating.
> PS : the tube is not part of the *environment*, so the errors I'm referring
> to are not the blob components passing through it.
> Comments and suggestions are still welcome.
It looks great !
It's obviously not water, but find a liquid with a high surface tension,
so that it does not wet the environment and that's it.
It also seems to be rather super-fluid... Liquid Hydrogen ? Quicksilver ?
My only regret is that there is nearly no continuous flow:
there is a opening phase, and a ending one, but no long lasting flow.
And I do not understand where the flow goes.
So that is how rubber balls are made. They just pour out the liquid
rubber mass on the floor, and it breaks up in perfect little spheres
that roll away. :-)
/Ib
That's pretty cool. I would make it a bit less bouncy and use more
particles, though. :)
I'm using 10000 particles here...
But it certainly still needs a lot of work, so I will try to lower the
elasticity (here 0.5).
The major problem here is to discover what is wrong with the algorithm I'm
using...
Thanks for the suggestions.
Jonathan
"Tony[B]" <ben### [at] catholic org> ha scritto nel messaggio
news:3bbded36@news.povray.org...
news:3bbdf04d@news.povray.org...
> using...
I can't see anything that suggest there is anything wrong with your
algorithm... What's it doing that you don't want it to, or not doing that
you do ?
Scott Hill.
Software Engineer.
Look at the bottom-left particles at the end of the animation: can you see
those particles passing through the *wall* and following the hidden part of
the sphere?
(Does what I've said make sense?)
Jonathan.
"Scott Hill" <sco### [at] innocent com> ha scritto nel messaggio
news:3bbe2d41@news.povray.org...
I'm
> > using...
> you do ?
> Scott Hill.
> Software Engineer.
