On 3-10-2018 12:48, Bald Eagle wrote:
> "Kenneth" <kdw### [at] gmail com> wrote:
>> The interesting thing about two-axis rotation is that the object *eventually*
>> assumes every possible orientation, at least according to the many visual tests
>> I've done (or else I'm much mistaken!)
> I was going to point out that if you think about this from a spherical
> coordinate standpoint - there is no difference.
> The distinction between 2 and 3-axis is artificial.
> Perhaps you're just "adding" or "fiddling" too much - adding a jitter where
> there ought to be a flow.
Yes, that is an important, if not fundamental, point.
