POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0 experimental versions : Re: POV-Ray v3.8.0 experimental versions Server Time
3 Dec 2021 02:32:16 EST (-0500)
Date: 19 Feb 2019 15:14:41
Message: <5c6c63b1$1@news.povray.org>
Le 19/02/2019 à 21:03, clipka a écrit :
> Am 19.02.2019 um 19:05 schrieb Le_Forgeron:
>> For the freetype, I now get:
>> for gnu compiler, disp_sdl.cpp is failing with min(), suggesting
>> std::min() (same for max / std::max)
> Did you pull the tagged version?
> If you instead pulled the `experimental/freetype` head, that would
> explain why you're seeing the issue: I forgot to push that branch, so
> it's lagging behind. The tagged branch is `autobuild/freetype`.
oh, far better with autobuild/freetype (yep, i was pumping
experimental/freetype).
Any push soon to fix master too ?
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
