David Bucciarelli wrote:
> The result of the following command "povray +W100 +H100 +SR0 +ER50 +FP
> +Otest.ppm test.ini" is an incorrect image.
> The header of the PPM file is:
> P6
> 100 100
> 255
> but it includes only 50 rows. The height of the image file should be 50
> instead of 100.
This is as intended, otherwise you could not append to the image file in
a continued trace. Also it has been this way in all previous versions
of POV-Ray and not just 3.6.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
