POV-Ray : Newsgroups : povray.beta-test.binaries : Function / pattern issues. New f_repeat(). : Function / pattern issues. New f_repeat(). Server Time
18 Jul 2026 10:23:29 EDT (-0400)
Date: 2 May 2020 11:22:15
Message: <5ead9027@news.povray.org>
<---------------------- References. Six previous posts
http://news.povray.org/povray.beta-test.binaries/thread/%3C5e9cce19%40news.povray.org%3E/
and
http://news.povray.org/povray.beta-test.binaries/thread/%3C5ea57285%241%40news.povray.org%3E/
In povr have implemented a new f_repeat() function which is like the
existing repeat warp in some respects, but mostly implements some
SDL/TCL functionality I've had in my toolbox for a while as an inbuilt
function with the significant improvement of embedding the cells like
pattern mapping so it need not be calculated and maintained apart.
My toolbox has a bunch of other half done stuff too, but thinking to
pile it all in one function likely to get sluggish, so leaving that for
probably another version - f_repeatMoreAndSlower() - or something. :-)
Parameters: x, y, z
Thirteen extra parameter required:
1.  If 0, return new x.
     If 1, return new y.
     If 2, return new z.
     If 3, return matched cells pattern value  0 to 1 interval.
     If 4, return matched cells pattern value -1 to 1 interval.
2.  Count in x.
3.  Count in y.
4.  Count in z.
5.  Delta in x.
6.  Delta in y.
7.  Delta in z.
Direction. If 0, count applied +-. If <0, count applied - only. If >0, count
applied + only.
8.  Direction in x.
9.  Direction in y.
10. Direction in z.
11. Cells pattern offset in x.
12. Cells pattern offset in y.
13. Cells pattern offset in z.
Notes. The base function should be centered at zero and small enough to
fit in the repeated 'cells.'  The counts too are in both directions
about the particular axis. So a y count of two means two on each side of
y. The deltas represent the size of each cell in x,y or z. The
directions are used to prune counts in particular directions. Lastly,
the cells offset exists, so if you have multiple instances of the
isosurface you can make them all look different with respect to textures.
#declare R = 0.070;
#declare cntV   = <+4.0,+1.0,+4.0>;
#declare deltaV = <+0.3,+0.3,+0.3>;
#declare dirV   = <+1.0,+1.0,+0.0>;
#declare coffV  = <+9.0,+9.0,+9.0>;
#declare Fn00 = function (x,y,z,r,ax,ay,az,bx,by,bz,cx,cy,cz,dz,dy,dz) {
     f_sphere(
         f_repeat(x,y,z,0,ax,ay,az,bx,by,bz,cx,cy,cz,dz,dy,dz),
         f_repeat(x,y,z,1,ax,ay,az,bx,by,bz,cx,cy,cz,dz,dy,dz),
         f_repeat(x,y,z,2,ax,ay,az,bx,by,bz,cx,cy,cz,dz,dy,dz),
         r
#declare Iso98 = isosurface {
     function {
         Fn00(x,y,z,R,
             cntx,cnty,cntz,
             dltx,dlty,dltz,
             dirx,diry,dirz,
             coffx,coffy,coffz
#declare Pgm00 = pigment {
     function {
         f_repeat(x,y,z,3,
             cntx,cnty,cntz,
             dltx,dlty,dltz,
             dirx,diry,dirz,
             coffx,coffy,coffz
     raw_wave
     color_map { ColorMap00 }
Image attached two isosurfaces though could have been one. Using the
same pigment for both.
Bill P.
Download 'story_f_repeat.png' (494 KB)
Preview of image 'story_f_repeat.png'
