POV-Ray : Newsgroups : povray.beta-test.binaries : Fixing longstanding function/pattern issues in v38. New raw_wave keyword. : Fixing longstanding function/pattern issues in v38. New raw_wave keyword. Server Time
8 Jun 2026 13:22:24 EDT (-0400)
Date: 19 Oct 2019 12:52:37
Message: <5dab3f55$1@news.povray.org>
In an earlier post to this newsgroup:
http://news.povray.org/povray.beta-test.binaries/thread/%3C5da5ba46%40news.povray.org%3E/
I started documenting longstanding bugs and issues with VM function and
pattern interplay. I believe as many as possible should be fixed in the
POV-Ray v3.8 release. Documenting these bugs/issues as I do my best to
find and fix them in my personal version of POV-Ray.
The internal kWaveType_Raw waveType clipka introduced with the new
potential(1) pattern should go the whole way and be available via a new
'raw_wave' keyword.
It's frustrating to recognition the core developers implemented
significant infrastructure which should make creating and manipulating
functions and isosurfaces via the pattern mechanisms easy - except often
it falls short.
Everything exists today to code and run:
//--- FnZZ used directly in an isosurface - attached image left column
#declare VarPlaneSheetThickness = 0.01;
#declare FnZ = function (x,y,z) { z-(VarPlaneSheetThickness/2.0) }
#declare FnZ_inv = function (x,y,z) {
     -(z)-(VarPlaneSheetThickness/2.0)
#declare FnZZ = function (x,y,z) { max(FnZ(x,y,z),FnZ_inv(x,y,z)) }
#declare VarPlaneSheetOffset = 0.8;
#declare FnZZOffset = function {
     pattern { function { FnZZ(x,y,z) }
   //raw_wave // Without middle column, with get intended result right.
     translate <0,0,VarPlaneSheetOffset>
     turbulence 0.1
#declare IsoPlaneZOffset = isosurface {
     function { FnZZOffset(x,y,z) }
     contained_by {
         box { <-1,-1,-0.20+VarPlaneSheetOffset>,
         <1,1,0.20+VarPlaneSheetOffset> }
     threshold 0
     accuracy 0.0005
     max_gradient 1.3
     max_trace 1
     pigment { color Indigo4 }
but the above code doesn't work though the developers enabled the
overall mechanisms.
The raw_wave keyword bypasses the usual pattern 'wave' modification code
- including the code below which makes manipulating functions with the
remaining pattern modifiers difficult(2) and very confusing.
Today one has to understand in detail how ALL the pattern wave modifiers
work and how to hack your functions to get past the issues to use the
warp/turbulence capability. Oh, and to use any pattern modified function
in with other functions. It's a huge pain. Anyway, the problem code for
many functions(3) is:
     /* allow negative frequency */
     if(value < 0.0)
         value -= floor(value);
Bill P.
(1) - Aside. I have concerns with the potential pattern for blobs and
isosurfaces as currently implemented for v3.8. Other than perhaps being
complete in providing an isosurface potential pattern, it doesn't make
much sense. Most anyone will just use the function into the isosurface
directly. Further, the keywords added code added slows all isosurfaces.
Lastly, with both blobs and isosurfaces the internal 'raw_wave' is hard
set on - preventing the use of the wave modifiers when they could be
used.
(2) - In the scene file provided for the thread referenced at top, it's
why this extra, but today, necessary code :
#declare Fn00f_Tiling11_3 = function {
     pattern { function { max(0,-Fn00e_Tiling11_3(x,y,z)) } }
Yes, the clamping hurts the gradient and to get something a little
better I code:
#declare Fn00_Tiling11_3 = function (x,y,z) {
     0.001-Fn00f_Tiling11_3(x,y,z)
instead of:
for the final isosurface function.
(3) - I have in mind an additional wave modifier keyword -
function_wave(?) - which bypasses only the problem code. Not yet worked
on it in detail. Aiming to allow most (or all) the existing wave
modifiers with it. Excepting of course the new raw_wave one which just
bails on that code.
Download 'raw_wavekeyword.png' (28 KB)
Preview of image 'raw_wavekeyword.png'
