Christoph Hormann wrote:
> David Bucciarelli wrote:
>> The result of the following command "povray +W100 +H100 +SR0 +ER50 +FP
>> +Otest.ppm test.ini" is an incorrect image.
>> The header of the PPM file is:
>> P6
>> 100 100
>> 255
>> but it includes only 50 rows. The height of the image file should be
>> 50 instead of 100.
> This is as intended, otherwise you could not append to the image file in
> a continued trace. Also it has been this way in all previous versions
> of POV-Ray and not just 3.6.
Mmmm, I understand your point however it is strange behavior because
opening the "test.ppm" file with xv, gimp or Java ImageIO API fails or
reports errors. Anyway I understand that this behavior is required by
the "+C" option.
Thanks anyway,
David Bucciarelli
