POV-Ray : Newsgroups : povray.advanced-users : Batch multi-core rendering server wrapper for povray Server Time
27 Sep 2024 11:26:28 EDT (-0400)
  Batch multi-core rendering server wrapper for povray (Message 1 to 5 of 5)
Subject: Batch multi-core rendering server wrapper for povray
Date: 24 Feb 2010 23:20:01
Message: <web.4b85f8dcf96d13da5c2e077e0@news.povray.org>
Hello all,
I'd like to share a useful utility I developed for running povray on a set of
scripts in parallel on multi-core servers. It's a simple C++ program (*nix &
MacOSX) that can be run in parallel from makefiles to render successive frames
of a scene with many threads of povray.
The source code is at:
    http://FASTLabInc.com/pov-render.cpp
Here's the header of the source.
stp
POV-Renderer -- Batch multi-core rendering server wrapper for povray
 (i.e., run povray on a set of scripts in parallel on multi-core servers)
 Stephen Pope - stp### [at] heaveneverywherecom - Dec, 2009, Feb, 2010
This program can be run from a make file in multiple threads to schedule
batch rendering with povray on multi-core machines. Each thread runs through
the frames in sequence using a frame# lock file for synchronization.
The typical Makefile entry is,
 # 2 renderer threads, each makes 600 out of 1200 frames for t = 0 to 1
 t4:
  echo 0 > frame_num
  nohup ./pov-render -n 600 -f 0 1200 -t 0.0 1.0 &
  sleep 2
The cmd "make t4" will now fork 2 processes, which the OS will allocate to their
own cores.
You can run more threads on multi-core machines by editing the Makefile.
The povray command generated to render frames in a thread has format:
/opt/local/bin/povray +W1920 +H1080 +FN +Q9 +KC
 +I/home/stp/POV/Sc12.pov +O/scratch/stp/Sc1200
 +L/opt/local/lib/povray-3.6.1/include +L/home/stp/POV
 +KFI0 +KFF1000 +KI0.0 +KF1.0 +SF81 +EF81
The details of the command options are in the C++ code below, and can be
overridden from the render command.
pov-render command flags
 -c command
 -n # frames to make
 -s starting frame
 -i in file
 -o out file
 -q quality
 -f F0 F1 -- start/end frame
 -t t0 t1 -- start/end time
 -x # threads
 -u print usage
Compile this program like, (in Makefile),
 # target to compile renderer
 re:
  g++ -o pov-render pov-render.cpp  # add -lpthread on Linux
Subject: Re: Batch multi-core rendering server wrapper for povray
Date: 25 Feb 2010 02:55:27
Message: <4b862cef$1@news.povray.org>
Nice. I've been content with just running folding@home on the other cores,
but this is nice.
Stephen Pope wrote:
> Hello all,
> of scripts in parallel on multi-core servers. It's a simple C++ program
> (*nix & MacOSX) that can be run in parallel from makefiles to render
> successive frames of a scene with many threads of povray.
> stp
> through the frames in sequence using a frame# lock file for
> synchronization. The typical Makefile entry is,
>  t4:
>   echo 0 > frame_num
>   sleep 2
> their own cores.
>  -c command
>  -n # frames to make
>  -s starting frame
>  -i in file
>  -o out file
>  -q quality
>  -x # threads
>  -u print usage
>  re:
Date: 25 Feb 2010 03:05:02
Message: <web.4b862eddf0ee27f65c2e077e0@news.povray.org>
A few extra notes to the pov-render driver program:
1. The program is "straight" C++ with no GUI; it compiles on Unix/Linux, MacOSX
and MS-Windows with std C/C++ libraries (or cygwin/DOS). The actual povray
command location is a #define in the code.
2. Macro #multithreaded is normally not used; each renderer task runs a single
thread.
3. pov-render can be run from make, shell/batch scripts, or a scripting language
like python or Smalltalk.
4. Partial batches can easily be restarted by editing the frame_num file (and/or
Makefile) and running make again.
5. The default in/out files are Default.pov and Default 0001.png (#define in the
code). These are changed either by compiling a version for each scene, or using
the -i and -o cmd-line options in the Makefile.
Enjoy! (I currently have it running on 30 or so cores here at UCSB -- since
October.)
stp
"Stephen Pope" <stephen [at] HeavenEverywhere [dot] com> wrote:
> Hello all,
 [ ...stuff deleted ]
>  re:
Date: 25 Feb 2010 10:34:48
Message: <4b869898@news.povray.org>
  What advantages does it offer over POV-Ray 3.7, besides consuming multiple
times as much memory (ie. as many times as there are processes running)?
Date: 2 Mar 2010 09:51:57
Message: <4b8d260d$1@news.povray.org>
> multiple
I saw 3.6.1 mentioned in his post, so I assume it is so you can use a
non-beta version of POV on a multi-core machine (they've been popular for
quite some years now).
