POV-Ray : Newsgroups : povray.advanced-users : bounded_by Server Time
27 Sep 2024 11:23:40 EDT (-0400)
  bounded_by (Message 1 to 10 of 12)
Subject: bounded_by
Date: 14 Jun 2010 18:01:35
Message: <4c16a6bf$1@news.povray.org>
Suppose I have the following CSG object:
   difference
     object {obj1}
     object {obj2}
Is there any benefit to adding a bounded_by statement like the following
where one of the objects is simply duplicated?
   difference
     object {obj1}
     object {obj2}
     bounded_by {obj1}
http://isometricland.com
Subject: Re: bounded_by
Date: 14 Jun 2010 18:45:33
Message: <4c16b10d$1@news.povray.org>
> difference
> object {obj1}
> object {obj2}
> difference
> object {obj1}
> object {obj2}
> bounded_by {obj1}
It depends.
If Obj1 only have a relatively small part removed and Obj2 is relatively
large, like a large sphere, and Obj1 is comparatively small, it can
restrict the bounding box back to a more resonable dimention.
It's not realy helpfull if Obj2 is small and simple, or is already
located totaly inside Obj1's bounding box.
Date: 14 Jun 2010 19:09:14
Message: <4c16b69a$1@news.povray.org>
> difference
> object {obj1}
> object {obj2}
> difference
> object {obj1}
> object {obj2}
> bounded_by {obj1}
It's probably related to your spinner colony.
If you remove a cylindrical piece from a building, you bounding box will
encompass the building AND the complete cylinder. In that case, YES,
you'll get some, possibly large, performance improvement.
Also, if you start with a large cylinder, remove an almost as large one
to get a curved floor, then chop away the sides to only keep the
buildin's floor, manual bounding with a box can greatly help you.
Date: 14 Jun 2010 20:57:17
Message: <4c16cfed$1@news.povray.org>
Am 15.06.2010 00:01, schrieb SharkD:
> difference
> object {obj1}
> object {obj2}
> bounded_by {obj1}
No. At best it has no effect; at worst it may even be slower.
Date: 14 Jun 2010 21:06:52
Message: <4c16d22c$1@news.povray.org>
Am 15.06.2010 01:09, schrieb Alain:
Actually no - POV-Ray is smarter than that (at least since version 3.6,
don't know about earlier ones).
The difference between an object obj1 and another object obj2 is
modelled as the intersection between obj1 and the inverse of obj2;
intersections' bounding boxes are computed as the intersection of all
member objects' bounding boxes, i.e. if obj1 has any bounding box at
all, then POV-Ray will never make the CSG's bounding box any bigger than
that.
Date: 14 Jun 2010 21:57:14
Message: <4c16ddfa$1@news.povray.org>
>> difference
>> object {obj1}
>> object {obj2}
>> bounded_by {obj1}
Thank you.
Can I use meshes inside bounded_by statements? I just did a quick test
and got an "Illegal texture or patch in clip, bound or object pattern"
error, so I'm assuming no.
Date: 14 Jun 2010 22:04:45
Message: <4c16dfbd@news.povray.org>
Also, in what order does POV-Ray parse the bounded_by statements?
// step 1
intersection
	// step 2
	difference
		// step 3
		intersection
			bounded_by {...}
		intersection
			bounded_by {...}
		bounded_by {...}
	difference
		intersection
			bounded_by {...}
		intersection
			bounded_by {...}
		bounded_by {...}
	bounded_by {...}
Date: 14 Jun 2010 22:15:04
Message: <4c16e228@news.povray.org>
Am 15.06.2010 03:57, schrieb SharkD:
Did you specify an inside_vector? I guess that POV-Ray will only accept
proper solids for bounding; meshes are considered solid only when you
specify an inside_vector.
Date: 14 Jun 2010 22:15:51
Message: <4c16e257$1@news.povray.org>
Am 15.06.2010 04:04, schrieb SharkD:
Innermost objects first.
Date: 15 Jun 2010 13:44:37
Message: <4c17bc05$1@news.povray.org>
Yes, it has an inside vector and works fine in CSG operations. I also
get the occasional "Patch objects not allowed in intersections" error,
though I haven't noticed any negative effects (yet).
