POV-Ray : Newsgroups : povray.advanced-users : 4D geometry Server Time
12 Nov 2025 07:39:16 EST (-0500)
  4D geometry (Message 1 to 10 of 18)
Subject: 4D geometry
Date: 2 May 2004 07:05:12
Message: <4094d5e8$1@news.povray.org>
Hi folks.
Firstly, has anyone looked into it? (4D geometry in POV-Ray that is.)
Part of the problem is that the fourth dimension is a little bit
mind-numbing to think about!
Anyway, I'd like to use POV-Ray to draw animations of a hypercube
rotating in 4 dimensions, orthographically projected into 3 dimensions.
If I'm not mistaken, a hypercube can be defined as the set of all points
that satisfy
   -k < (x, y, z, w) < +k
It can also be defined as the intersection of 8 hyperplanes - and this
lents itself for to rotation.
Suppose we have a hyperplane
   Ax + By + Cz + Dw - E = 0
Then the "normal" would be <A, B, C, D> and the distance from the origin
would be E. (In 2D, a normal defines a line. In 3D, a normal defines a
plane. So presumably in 4D a normal defines a hyperplane...)
If (say) <A, B, C, D> = <0, 1, 0, 0>, then an orthographic projection
into 3D gives us an ordinary plane with normal <0, 1, 0>.
However...
As far as I can tell, if you rotate that hyperplane off the axis even
slightly (in such a way that D <> 0), then the 3D projection of that
hyperplane fills the entire 3D space. That would mean that if I do any
double rotation by a small angle, *all* 8 projections would fill all of
3D space, resulting in... well... nothing.
Question: is the intersection of the 3D projections of the 8 hyperplanes
equal to the 3D projection of the intersection of the 8 hyperplanes?
(Question: Does that even make sense?!)
Thoughts / suggestions?
Andrew @ home.
Subject: Re: 4D geometry
Date: 2 May 2004 14:42:58
Message: <cjameshuff-4E44F5.14420802052004@news.povray.org>
In article <4094d5e8$1@news.povray.org>,
Other than Julia fractals and crackle offset, not that I know of. You
should be able to render a 3D "slice" pretty easily with isosurfaces.
Something like this:
#declare Box4DFn = function {max(abs(x), abs(y), abs(z), abs(t))}
Then you just have to come up with a rotation to compute the xyzt
coordinates...a box with an axis aligned to the t axis isn't very
interesting. It's either an ordinary box, or nothing. This page seems to
have some info: http://www.geocities.com/igorelik/4rotat.html
http://tag.povray.org/
Date: 3 May 2004 04:49:20
Message: <409607D6.7080405@informatik.uni-freiburg.de>
I have done 4D-geometry visualization long before raytracing. That was
wireframe for red/green glasses. I haven't done it in povray.
I always prefered perspective projection.
Anyway, you seem to want to use a solid 3D object. You will lose a lot of
the 4D information that way. The 4D object has vertices, edges, faces,
and hyperfaces as "visual" elements of its geometry. By your method you
lose all vertices, edges, and faces that are projected to the inside of
the 3D model. You also lose all hyperfaces alltogether.
For povray I could think of several alternatives:
1. Do a wireframe model using spheres and cylinders -- or one large
    spheresweep (after all the graph of the hypercube does have a Eulerian
    cycle). Vertcies and edges will be clearly visible, faces and hyperfaces
    sort of.
2. Show the faces as semitransparent polygons. Possibly of different colours.
    Vertices, edges, and faces are visible, hyperfaces sort of. The faces will
    maybe be too many to not be confusing.
3. Show the hyperfaces by differently coloured media.
Or, maybe, use a combination.
No. and that is not a feature unique to 4D->3D. An example in 2D-1D:
Consider the normal vectors (1,1) and (1,-1) and work it out. Another
example: Take the sets {(0,0),(1,1)} and {(0,1),(1,0)}. Projection, then
intersection yields {0,1}, while the other way around you obtain the empty
set. The first collects all 1D-points that can be extended to some point
in each of the original sets. The second collects all 1D-point that have
one extension that pertains to both sets simultaneously.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 3 May 2004 08:22:54
Message: <4096399e@news.povray.org>
Likewise. (I wrote a Java thingy... but Java is just painful!)
Yeah, I know what you mean... Only trouble is working out which effects
are due to the 4D->3D perspective, and which ones are the 3D->2D
perspective! ;-)
Yeah, true.
>    sort of.
I was planning to do this too. But working out where the hell the edges
are seems like a harder problem then just telling POV-Ray to take the
intersection of some simple planes.
> colours.
> will
This could work - I think anyway! :-S
Ooo... hadn't thought of that!
>> hyperplanes equal to the 3D projection of the intersection of the 8
>> hyperplanes?
Right...
So figuring out how to project the 8 hyperplanes into 3D and then asking
POV-Ray for the intersection will get me nowhere fast. (I was already
beginning to suspect this conclusion, which is why I asked! ;-)
Maybe I'll have a go at the wireframe bit for a while...
Thanks.
Andrew @ home.
Date: 3 May 2004 08:26:39
Message: <40963a7f$1@news.povray.org>
...and 4D noise I would imagine...
> You
OK, will take a look.
Thanks.
Andrew @ home
Date: 3 May 2004 12:10:36
Message: <40966F3F.1090100@informatik.uni-freiburg.de>
> perspective! ;-)
I never had problems with that, but the red/green glasses might have
helped a lot on that one. The problems I had were with too many lines
when having many 4D objects in the same "scene". I'm talking about 4D
tetris here.
>> hyperfaces
>>    sort of.
You have 16 vertices. It is best to think of them as 4-bit words. The
bit i controls wether the coordnate i is -1 or 1. Then you have a line
between vertex n and vertex m if and only if n and m differ by exactly
one bit (or have 3 bits in common). A face consists of 4 vertices that
have 2 bits in common and a hyperface consists of 8 vertices that have
1 bit in common.
> Thanks.
You are welcome
Date: 3 May 2004 14:02:35
Message: <4096893b$1@news.povray.org>
>> effects are due to the 4D->3D perspective, and which ones are the
>> 3D->2D perspective! ;-)
> tetris here.
??!?! :-| ?!/"\@_~??!
Four *&$^ dimensional *@$^%# tetris *@*@#?!?! :-|
OK, my head hurts... lol!
>>> Eulerian
>>> hyperfaces
>>>    sort of.
>> edges are seems like a harder problem then just telling POV-Ray to
>> take the intersection of some simple planes.
> 1 bit in common.
I just spent about 2 hours figuring that out. POV-Ray is running an
animation as we speak.
Thanks.
Andrew @ home.
Date: 3 May 2004 14:22:32
Message: <40968de8@news.povray.org>
Out of interest... I'm told there's an amazing 4D object that has 1200
sides or something stupid... anyone know how I compute the corners and
join them up to make a wireframe?
Thanks.
Andrew @ home.
Date: 3 May 2004 14:29:52
Message: <40968fa0@news.povray.org>
>>> hyperplanes?
>> empty
> Right...
Here's another question... what about slicing? If I choose a particular
value for the 4th ordinate and fix that, can I *then* do the
intersection on 3D? (Taking a slice is after all a set intersection
operation - and I *believe* those things are associative...)
Andrew @ home.
Date: 3 May 2004 18:13:46
Message: <4096c41a@news.povray.org>
> Thanks.
> Andrew @ home.
You might want to check out Paul Bourke's discussion of higher dimensions:
http://astronomy.swin.edu.au/~pbourke/polyhedra/platonic4d/
Here he displays, among other things, a 2d projection of a 3d projection
of a 4d object with "600 tetrahedral cells, 1200 triangular faces, 720
edges, 120 vertices" -- probably the one you're thinking of.
Dave Matthews
