POV-Ray : Newsgroups : povray.advanced-users : ifdef() Server Time
12 Nov 2025 07:39:17 EST (-0500)
  ifdef() (Message 1 to 5 of 5)
Subject: ifdef()
Date: 3 Mar 2004 11:32:31
Message: <4046089f$1@news.povray.org>
Hello,
I'm using the following construct for my code:
#declare A = array[2];
#declare B = array[2];
#declare B[0]=A;
#declare B[1]=A;
#declare B[0][0] = 18;
#ifdef (B[0][0])
 #debug "This is defined"
If you use this the parser stops in the line #ifdef (B[0][0]) with the
cursor between [0] and [0] and says that it expects a closing bracket ')'.
(1)
There is no problem with assigning a value but testing is obviously not
possible.
You can circumvent this with:
#declare T=B[0];
#ifdef(T[0])
My question is why you can assign a value but can't test the existence of
the value in one step. Shouldn't it work as I was expecting?
Jaap Frank
PS  This is with the windows version 3.5.
       With 3.6 the cursor stops one character earlier.
Subject: Re: ifdef()
Date: 3 Mar 2004 11:48:38
Message: <40460c66@news.povray.org>
Jaap Frank wrote:
> Hello,
> #declare B[0]=A;
> #declare B[1]=A;
why don't you use a two-dimensional instead of asigning one array to the
other?
#declare A = array[2][2];
this works well for me. but maybe i misunderstood you...
bye,
	Marc
Date: 3 Mar 2004 12:09:56
Message: <40461164@news.povray.org>
"Marc Roth" <mar### [at] rothconsultcom> wrote in message
news:40460c66@news.povray.org...
> Jaap Frank wrote:    [..]
> one array to the other?
> bye,
> Marc
I've simplified the problem to show what I mean, but in reality my arrays
are build that way in order to be able to transfer parts of my arrays to a
macro that uses only a part of the total array. Like #declare T=B[0];   in
my example.
I've to test if the array value already exists to prefent
dubbel calculations.
This is by the way the method to put different kind of variables in one
array, so you can pass lots of different things in one array to a macro:
#declare A = array[2] { 2.05, 3.0058}
#declare B = array[2] { <1,2,3>, <4,5,6>}
#declare C = array[2]
#declare C[0] = A;
#declare C[1] = B;
#declare F =C[0][1]   // Is a float
#declare V = C[1][0]  // Is a vector
Thanks for your reaction,
Jaap Frank
Date: 3 Mar 2004 12:19:44
Message: <404613b0@news.povray.org>
In article <4046089f$1@news.povray.org> , "Jaap Frank" <jjf### [at] xs4allnl>
> possible.
You cannot test if an array element is defined, that does not make sense at
because the array is either defined or not, independent of the elements.
The manual at no point claims what you want to do would be possible.  If you
want to know if a specific element exists, you should use the array size,
and simply not add elements that do not contain the information you do not
want to store in the first place.
    Thorsten
e-mail: tho### [at] trfde
Date: 3 Mar 2004 13:04:47
Message: <40461e3f@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:404613b0@news.povray.org...
> > possible.
at
you
>     Thorsten
Thorsten, I'm sorry for talking about defining, I ment assigning:
| From the manual:
| The #ifdef and #ifndef directives can be used to determine whether
| a specific element of an array has been assigned.
| #declare MyArray=array[10]
| //#declare MyArray[0]=7;
| #ifdef(MyArray[0])
|    #debug "first element is assigned\n"
| #else
|    #debug "first element is not assigned\n"
|  #end
You can assign an value in one step in my example, but you can't test
in one step if a value is assigned.
Is it wrong to expect that the test could be done in one step?
(By the way, I can't follow your last sentence, it contains to
many negations, but I think you mean something like you can't test
something that's not existing.)
Jaap Frank
