POV-Ray : Newsgroups : povray.advanced-users : temporally coherent noise? Server Time
12 Nov 2025 09:43:08 EST (-0500)
  temporally coherent noise? (Message 1 to 4 of 4)
Subject: temporally coherent noise?
Date: 10 Feb 2004 03:10:16
Message: <402891e8$1@news.povray.org>
Hi ALL,
I have been using the "Turbulence" function to add noise to the color in the
media. But as we know turbulence is coherent in space. But to generate a
sequence of renderings (e.g. an explosion cloud evolving in time) a noise
function needs to be temporally coherent. Otherwise, if the same noise is
applied to a point at all the steps in time, then the animation will have
the classical "shower curtain effect" cited in literature. So, can anyone
please suggest if there is a way to generate such a noise in POVRAY,
somethings that looks spatially as well as temporally coherent?
Thanks in advance,
Maurya
http://www-scf.usc.edu/~mauryash
Subject: Re: temporally coherent noise?
Date: 10 Feb 2004 07:18:45
Message: <cjameshuff-5C2251.07190510022004@news.povray.org>
In article <402891e8$1@news.povray.org>,
I'm not familiar with the "shower curtain" effect. However, noise is
temporally coherent in that it is constant and deterministic, you always
get the same results for a given 3D point. It sounds like what you want
is a 4D pattern, a noise function that varies smoothly with time. This
is possible, I even once saw a recursive implementation of Perlin noise
that could handle any number of dimensions, but slower to compute and
more complex, and I don't know if it has been done in POV.
If your use of the pattern is constrained to two dimensions, a floor
plane for example, then you can just move the pattern along the
remaining dimension. Or you could combine several noise functions in
various ways, and translate them in different directions.
http://tag.povray.org/
Date: 12 Feb 2004 00:18:10
Message: <402b0c92@news.povray.org>
Hi Christopher,
Thanks for your comments.
I tried to review some literature about Perlin noise and it seems that if
the noise has to varied smoothly both in space and time then I feel the use
of advected textures is the only way out. I found the paper called "Advected
Textures" by Fabric Neyret to be quite interesting and claims to have solved
this problem successfully. The basic idea is to combine multiple texture
noise together and vary them over time so that the statistical property of
noise is maintained as well as the noise follows the local distortion of the
media.
However, implementing this is quite a bit of work.
Maurya
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cjameshuff-5C2251.07190510022004@news.povray.org...
the
noise
is
have
anyone
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
Date: 12 Feb 2004 08:01:37
Message: <cjameshuff-034960.08020112022004@news.povray.org>
In article <402b0c92@news.povray.org>,
This is not so. There is a 4D variant of Perlin noise which does exactly
that, varying in time as it varies along x, y, and z. In fact, Perlin
noise can be extended to any number of dimensions, though I doubt more
than 4 is very useful. Ah, SlimePOV has an implementation:
http://www.slimeland.com/slimepov/
