POV-Ray : Newsgroups : povray.advanced-users : specular highlight bug? Server Time
12 Nov 2025 15:55:35 EST (-0500)
  specular highlight bug? (Message 1 to 10 of 12)
Subject: specular highlight bug?
Date: 23 May 2003 15:39:33
Message: <3ece78f5$1@news.povray.org>
Why does the specular highlight vanish if I make my light source shadowless?
Is there any way round this?
simple test scene:
//the blue light has a specular highlight, the red does not.
sphere { z*3, 1 pigment { rgb .5 } finish { specular 1 roughness 0.01 } }
light_source { <-1,1,-1>*1000 rgb <1,0,0> shadowless }
light_source { <1,1,-1>*1000 rgb <0,0,1> }
Any help would be much appreciated, it's causing massive slowdown in my render
to test shadows for 50 light sources.
Tek
http://www.evilsuperbrain.com
Subject: Re: specular highlight bug?
Date: 23 May 2003 16:34:33
Message: <3ece85d9$1@news.povray.org>
Not a bug, a feature. Shadowless light_sources were designed to be used
as fill lights, to simulate interdiffuse reflections which produces no
noticeable highlights. I guess removing the highlights gave a speed
boost also.
I know of no speedwise workaround.
Povingly,
Philippe
Date: 23 May 2003 16:47:30
Message: <3ece88e2@news.povray.org>
3ece78f5$1@news.povray.org...
Try using light_groups.
camera {location  -z*5+y*5 look_at   y}
light_group{
    light_source{-z*1000, rgb 1 rotate x*40 rotate y*40}
    sphere{0,1 translate y pigment{rgb x} finish{phong 1}}
    global_lights off
plane{y,0 pigment{rgb 1} }
light_source{-z*1000, rgb 1 rotate x*40 rotate y*40 shadowless}
BTW, that was one of the reasons we used a lot of light groups in the space
image (www.oyonale.com/iss) so that objects wouldn't project shadows on each
other and still have highlights.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 23 May 2003 17:35:16
Message: <3ece9414@news.povray.org>
Well my problem is that I have a light dome with 50 light sources, so if I have
shadows turned on at all there's a significant performance hit, even when just
testing for self-shadowing.
Ah well, I guess I should just be more patient and allow more time for
rendering.
Tek
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3ece88e2@news.povray.org...
> light_group{
>     global_lights off
> G.
> - POV-Ray and Poser computer images
> - Posters
Date: 23 May 2003 17:36:49
Message: <3ece9471$1@news.povray.org>
We could do with a seperate no_specular tag or something...
Ah well, it's not a big enough problem for me to bother writing my own patched
version of POV :)
Tek
"Philippe Debar" <phd### [at] wanadoobe> wrote in message
news:3ece85d9$1@news.povray.org...
> boost also.
> Povingly,
> Philippe
Date: 24 May 2003 02:40:03
Message: <3ecf13c3@news.povray.org>
In article <3ece88e2@news.povray.org> , "Gilles Tran" <git### [at] wanadoofr>
Well, that is after all one of the main reasons why light_groups exist :-)
And they are also fairly fast, or, to be precise, there is next to no speed
penalty on objects not lit by those light sources.  Nevertheless,
light_groups could still be a bit faster if shadow rays could be controlled
as well as some people have requested in the past...
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 24 May 2003 11:25:01
Message: <web.3ecf8e07ac50e57f84d065310@news.povray.org>
Yap.. That isn't bug. But I have found a serious problem from POV-Ray
highlights. It's impossible to create some metallic highlights because
POV-Ray takes highlight color from DIFFUSE reflectance..
Matti
Date: 25 May 2003 17:59:34
Message: <3ed13cc6@news.povray.org>
Um... specular highlights take their colour from the light source [and the
pigment colour if it's metallic]. They're not directly related to the diffuse
property.
Tek
"Matti Karnaattu" <nomail@nomail> wrote in message
news:web.3ecf8e07ac50e57f84d065310@news.povray.org...
> Matti
Date: 26 May 2003 03:19:18
Message: <3ed1bff6$1@news.povray.org>
diffuse
> property.
Unless you're specifying "metallic"
 - Slime
[ http://www.slimeland.com/ ]
Date: 26 May 2003 03:22:25
Message: <3ed1c0b1@news.povray.org>
But I thought that objects in one light group still projected shadows on
objects in a different light group?
 - Slime
