POV-Ray : Newsgroups : povray.advanced-users : File Read Problem Server Time
12 Nov 2025 15:55:35 EST (-0500)
  File Read Problem (Message 1 to 3 of 3)
Subject: File Read Problem
Date: 19 Apr 2003 17:36:50
Message: <3ea1c172@news.povray.org>
I am trying to use a file read to both position an object as well as
establishing the objects color..
The positioning is displaying correct as expected but the color is only
displaying as white.
#fopen DAT_File "C:\IMGdat.dat" read
#while (defined(DAT_File))
        #read (DAT_File, C1,C2,C3)
        sphere { <C1,C2,C3> 2 pigment{color rgb <C1, C2, C3>}}
Can somebody suggest what may cause the problem.
David
Subject: Re: File Read Problem
Date: 19 Apr 2003 21:49:42
Message: <3ea1fcb6@news.povray.org>
  That's probably because C1, C2 and C3 are larger than 1.
  You have to divide them with a value which scales them into the range
0-1 in order to get a color.
Date: 19 Apr 2003 22:00:18
Message: <3ea1ff32@news.povray.org>
Hi David,
I've checked your code with
   Windows 2000 Professional
   POV-Ray 3.5.icl.win32
using  the following IMGdat.dat file:
1, 0, 0,
0, 1, 0,
0, 0, 1,
1, 1, 1,
This gave four overlapping spheres with the expected colors: red, green,
blue, and white. The only reason for your error I can think of is "color
overflow": are you sure all your C1, C2, C3 are >=0 and <=1?
   Sputnik
