POV-Ray : Newsgroups : povray.advanced-users : Importing DXF, WMF etc Server Time
12 Nov 2025 17:39:24 EST (-0500)
  Importing DXF, WMF etc (Message 1 to 10 of 13)
Subject: Importing DXF, WMF etc
Date: 14 Mar 2003 08:24:33
Message: <3e71d811$1@news.povray.org>
Is it possible to "import" objects or shapes created in other graphics
drawing programs such as DXF meshes, WMF etc.
In particular I have a shape which I created in CorelDraw which I can
obviously export in various formats, and I'd like to be able to use it in
PovRAY in an extruded form.
Is this possible in PovRAY, or by using a pre-processor?
I'd also like to know if DXF meshes can imported into PovRAY.
Thanks
Colin
Subject: Re: Importing DXF, WMF etc
Date: 14 Mar 2003 10:11:01
Message: <3E71F1C5.DE8F04C8@pacbell.net>
It is tyipically very difficult to translate 2D image formats into a
3D environment other than simply using them as image maps to texture
existing 3D objects. The other alternative is to try to use a 2D
image to create a height field which will create a 3D shape from
a 2D image file format, but it has limitations.
There are several utilities that will allow you to convert from various
3D file formats to POV-Ray. The most popular are 3DWin and CrossRoads3D.
3DWin is shareware and is the most capable. Both will handle dxf2pov
conversions. Links to those and other conversion utilities can be found
at povray.org -
http://www.povray.org/resources/links/3D_Programs/Conversion_Utilities/
Ken Tyler
Date: 14 Mar 2003 13:09:30
Message: <cjameshuff-14312E.13094114032003@netplex.aussie.org>
In article <3e71d811$1@news.povray.org>, "CB" <col### [at] nospamcouk>
There are converters that can handle some of these things...I'm pretty
sure there's a DXF to POV converter, but I've never heard of WMF.
Hmm...I assume this is a vector drawing? Someone recently posted a
converter that generated POV-Ray prism objects from PDF or PostScript
files. Look in povray.binaries.utilities.
Alternatively, you could convert it to a black and white raster image
and use that as input for a height field. This isn't very efficient, and
has problems from the use of a height field (you might have trouble
getting the sides to look OK), but it might work.
http://tag.povray.org/
Date: 14 Mar 2003 19:02:53
Message: <3E726E6F.2BA68C7A@pacbell.net>
Windows Meta File format. WMF is the native vector file format for the
Microsoft Windows operating environment. WMF files are actually a
collection of GDI (Graphics Device Interface) function calls also
native to the Windows environment. When a WMF file is "played back"
(typically using the Windows PlayMetaFile() function) the graphics is
rendered. WMF files are device-independant and have no limit to their
size.
Ken Tyler
Date: 15 Mar 2003 05:04:15
Message: <3e72fa9f@news.povray.org>
"CB" <col### [at] nospamcouk> schrieb im Newsbeitrag
news:3e71d811$1@news.povray.org...
> Thanks
> Colin
I think Corel can export TrueType fonts. Maybe you can export a font
containing your shapes, and then use Elefont to make objects out of them.
Daniel
Subject: RE: Importing DXF, WMF etc
Date: 15 Mar 2003 15:29:38
Message: <3e738d32@news.povray.org>
You can use Wings 3D to import Adobe Illustrator files (.ai).
If you are using CorelDraw you can export your shape to
.ai format and open it in Wings 3D and extrude it there.
Later you can export the result to Povray as a mesh.
Wings 3D is available at:
http://www.wings3d.com/
As the others said, Crossroads 3D or 3Dwin are a good solution.
Bye
Txemi Jendrix
http://www.txemijendrix.com
Date: 15 Mar 2003 17:16:29
Message: <cjameshuff-7DB84D.17164215032003@netplex.aussie.org>
In article <3E726E6F.2BA68C7A@pacbell.net>, Ken <tyl### [at] pacbellnet>
> size.
Ah...sounds like a clone of the PICT format.
Date: 18 Mar 2003 21:40:11
Message: <3e77d88b@news.povray.org>
The now free Truespace3.2 is another real good solution for this. It can
import the vector files (ai,eps,dxf) and then you can extrude them and save
in 3ds. Win3d can convert the 3ds to pov.
I did this for many years creating component illustraction.
Corel Draw and Truespace.
"CB" <col### [at] nospamcouk> wrote in message
> Thanks
> Colin
Date: 24 Mar 2003 12:01:51
Message: <3e7f39ff$1@news.povray.org>
"Micheal (Mike) Williams" <mic### [at] quixnetnet> wrote in message
news:3e77d88b@news.povray.org...
save
Thanks, Michael. That sounds like an interesting solution. I'll have a look
at
Truespace's web site to see if it is available as a download.
I had managed to get another solution to this before I saw your note (see
my other note which I'm just about to write!)
Colin
Date: 24 Mar 2003 12:15:00
Message: <3e7f3d14@news.povray.org>
"Daniel Prien" <wil### [at] gmxnet> wrote in message
news:3e72fa9f@news.povray.org...
in
Thanks Daniel. This worked surprisingly well. The CorelDraw shape was
composed of  6 enclosed curves and when "Combine"-ed I was able to
export the shape as a TrueType font character. CorelDraw seems to use the
bottom-left of the page as the origin for the "character" so you have to
make
sure that the shape is against that corner of the page before exporting.
I was a little sceptical, but when I loaded the ttf into Elefont it was OK.
I could
apply all of the different bevelling types and amounts, and then export it
as
a POV mesh of triangles.
I was a little disappointed that Elefont did not use smooth_triangle for the
curved sides (which I think the Polyray ttf processing utility did), unless
there
was a hidden option I overlooked. But when I set it to export at the highest
quality level I found that for my application the smooth sides looked OK in
the final POV render.
It looks like Elefont has not been updated for the last few years so I doubt
there will be any more enhancements.
Colin
