POV-Ray : Newsgroups : povray.advanced-users : Is there a neater way of doing this? Server Time
12 Nov 2025 17:55:59 EST (-0500)
  Is there a neater way of doing this? (Message 1 to 5 of 5)
Subject: Is there a neater way of doing this?
Date: 20 Jan 2003 11:48:19
Message: <3e2c2853$1@news.povray.org>
Greetings, all.
I have a scene which requires rendering first using one set of .ini settings
and a particular camera outputting to a file (first.png). The scene then
requires running the file again using first.png as an image map, removing
one or two objects that were rendered in the first scene and adding others
and using totally different camera and .ini settings. (If you think
surrealist esp. Magritte, then you're on the right track).
So far I've been using this shell script to work it:
#!/bin/sh
povray firstrun.ini -d TestFile.pov
povray secondrun.ini TestFile.pov
#eof
where firstrun.ini defines an image size of 800x600 and
Output_File_Name=first.png, secondrun.ini defines an image size of 1024x768
and Output_File_Name is left as default TestFile.png. Further, TestFile.pov
tests for image_width and, using the normal structures, includes or ignores
the required objects. This works, but.....
... is there a neater way of doing this? i.e. not having to rely on the
shell script and also doing the whole thing as a single run.
John
Run Fast
Run Free
Run Linux
Subject: Re: Is there a neater way of doing this?
Date: 20 Jan 2003 11:54:15
Message: <r6ao2v0apmise977bk4roohvkvusmna7fd@4ax.com>
On Mon, 20 Jan 2003 16:42:15 -0000, "Doctor John" <jgu### [at] netscapenet>
you can start second render as post_scene_command probably. Look at 5.2.4
Shell-out to Operating System http://www.povray.org/documentation/view/130/
ABX
Date: 20 Jan 2003 12:04:41
Message: <3e2c2c29$1@news.povray.org>
> ABX
Hmm, I thought about that and will try it when I get home tonight but I have
a horrible feeling that it might not work as hoped.
The other point, not actually verbalised by me in the post, was that the
file takes ages to parse and I was hoping to save time by not having to
parse twice.
BTW Thanks for pointing out my original FieldCam post to everyone whilst I
was ill.
John
Run Fast
Run Free
Run Linux
Date: 20 Jan 2003 12:22:40
Message: <qebo2vkbbpv2s8k2268k67pm2tilbq4bno@4ax.com>
On Mon, 20 Jan 2003 17:02:15 -0000, "Doctor John" <jgu### [at] netscapenet>
In case if you could somehow unify ini settings you could of course try
two-frames long animation with cameras and objects selected with build-in
'frame_number' keyword. But I suppose you have different ini files for
important resons. There was 'ini_option' feature in old MegaPOV and it could
help in this case but I don't know if it will be ported again to reworked
MegaPOV. I can't recall requests for this particular feature recently :-)
> parse twice.
No doubts some of next releasses of MegaPOV will have some kind of
camera-based pigment/pattern. Such patches are already available IIRC. So you
could use separated locations in space to create envrionment for first image
and another locations in space to create environment for second image with
used image_maps over first location. I hope it is readable explanation.
> was ill.
No problem.
ABX
Date: 20 Jan 2003 12:55:21
Message: <3e2c3809$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:qebo2vkbbpv2s8k2268k67pm2tilbq4bno@4ax.com...
> important resons.
I do. :-)
So here's a request
you
Very readable. Thanks for quick replies.
John
Run Fast
Run Free
Run Linux
