POV-Ray : Newsgroups : povray.advanced-users : transparent meshes Server Time
14 Nov 2025 12:49:30 EST (-0500)
  transparent meshes (Message 1 to 8 of 8)
Subject: transparent meshes
Date: 17 Aug 1999 07:12:32
Message: <37b943a0@news.povray.org>
Hi
I've just created a figure in Organica, outputted it in 3ds the converted it
to pov smooth triangle in 3dWin ver 4.
The result what I expected except when rendered the figure is transparent.
I've tried everything I can think of to no avail.
I've never had this problem before and I am at a complete loss as to why it
should have come about.
BTW I'm using the superpatch.
Any help or advice would be gratefully received. I can provide the files if
it would help, though the figure file is quite
large.
Thank in advance
Mick
Subject: Re: transparent meshes
Date: 17 Aug 1999 07:18:56
Message: <37B94511.4BEDF2C3@pacbell.net>
Mick Hazelgrove wrote:
> Hi
> large.
> Thank in advance
> Mick
There have been some weird problems with the superpatch and meshes lately.
Have you verified it with the official version ?
Even as I type this I am rendering a diamond created with triangles and I
am having no problems with tranparency in the official version. Before I
added an ior value it was invisible.
If you can' figure it out I would be glad to check it our for you. I have
no problems with big ol meshy files.
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Date: 17 Aug 1999 14:53:36
Message: <37b9afb0@news.povray.org>
The problem disappears when I use a normal colour rgb statement. It's only
there when I use Gray50 type quick colour statements
Mick
Mick Hazelgrove <mha### [at] mindaswinternetcouk> wrote in message
news:37b943a0@news.povray.org...
> Hi
it
it
if
> large.
> Thank in advance
> Mick
Date: 17 Aug 1999 14:55:31
Message: <37b9b023@news.povray.org>
Can you show us a representative line or two of the file that causes the
problem without posting/sending the whole thing?  Specifically, the texture
you're applying.
Date: 17 Aug 1999 15:02:28
Message: <37b9b1c4@news.povray.org>
#declare ManTex = texture{
    pigment{color rgb<.5.5.5>}// this works
    pigment{Gray95}// this is transparent
        finish{ambient .01 diffuse .3}
            normal{bumps scale .0001}
Ron Parker <par### [at] fwicom> wrote in message
news:37b9b023@news.povray.org...
only
texture
> you're applying.
Date: 17 Aug 1999 15:13:28
Message: <37b9b458@news.povray.org>
This is weird now it seems to have something to do with the scale of the
normal
Mick
news:37b9b1c4@news.povray.org...
> only
> texture
> > you're applying.
Date: 17 Aug 1999 15:22:54
Message: <37b9b68e@news.povray.org>
>only
>texture
>> you're applying.
I can't duplicate this with my build of the Superpatch, with either mesh
or mesh2.  What do you get when you render the scene below?
    //pigment{color rgb<.5.5.5>}// this works
camera {location <0,0,-10> look_at 0}
light_source {<-20,-20,-20> rgb 2}
plane {-z,-5 pigment {bozo}}
//mesh {
//  triangle {x,y,z texture {ManTex}}
mesh2 {
  vertex_vectors {3, x,y,z }
  texture_list {1, texture{ ManTex }}
  face_indices {1, <0,1,2>,0 }
Date: 17 Aug 1999 23:31:26
Message: <37BA29B6.2878C541@Kopp.com>
At first I thought it might be the double-illumination problem, but that
has been 'fixed' in the Superpatch...
-Nathan
