POV-Ray : Newsgroups : povray.advanced-users : Macro and parameters : Re: Macro and parameters Server Time
10 Dec 2025 13:27:10 EST (-0500)
Date: 28 Nov 2025 12:45:00
Message: <web.6929df248e84ac71500040e3f712fc00@news.povray.org>
kurtz le pirate <kur### [at] freefr> wrote:
> Hello,
> I just spent a long, long time debugging my code.
> For example, this macro :
> #macro binomial_coefficient(n, k)
>    #local result = 0.0;
>    #if ( k<0 | k>n)
>    #elseif (k=0 | k=n)
>      #local result = 1.0;
>    #else
>      #if ( k > n-k )
>        #local k = n - k;
>      #end
>      #local i = 0;
>      #while ( i < k )
>        #local result = result*(n-i);
>        #local result = result/(i+1);
>        #local i = i + 1;
>      #end
>    #end
>    // return scalar value
>    result
> #end
> At first glance, nothing special, but there is a problem, a big problem,
> that I hadn't noticed :(
> Can you see it too? Well done.
> I also program in C, so perhaps that's where the confusion comes from.
> But I'll explain it anyway.
> The annoying part is this one :
>      #if ( k > n-k )
>        #local k = n - k;
>      #end
> ... and so, the "#local k =" led me to believe I was using a local
> variable. Well, not at all. "k" represents the variable passed as a
> parameter and its value is modified in the part that called this macro.
> By simplifying :
> #declare n = 5;
> #declare k = 3;
> #declare r = binomial_coefficient(n,k);
> ...and here k = 2, not 3 !
> Therefore, be careful not to use a macro parameter in an assignment.
> Do you agree with me, or have I misunderstood something again?
> kurtz le pirate
> compagnie de la banquise
I agree! I program in C++ and POV macros and variables are very different!
Try this macro.
#macro ts(R)
 #local R=sphere{0,1 pigment{Gold}}
#declare P=5; ts(P)
object{P}
Have Fun!
