POV-Ray : Newsgroups : povray.advanced-users : mesh_camera : Re: mesh_camera Server Time
15 Nov 2025 20:14:49 EST (-0500)
  Re: mesh_camera
Date: 6 Oct 2025 07:40:00
Message: <web.68e3aa17e548611c16086ed06830a892@news.povray.org>
"Paul Bourke" <pau### [at] gmailcom> wrote:
> I have the need for a custom camera, specifically an omni directional
> stereoscopic panorama (cylindrical, not equirectangular). I've done this in the
> long distant past by modifying the source and building my own version.
> I thought I would try the mesh_camera but it seems not as useful as I imagined.
> I can readily create the meshes and am getting the right results but ...
> 1. Loading the mesh takes a very long time for high resolution images. The LED
> cylinder I'm creating for is 12816x2048 pixels, even for 1/4 resolution tests
> the mesh loading takes longer than the rendering and it's probably 16x longer
> for the full resolution.
> 2. Is there there still no efficient/clean way to do antialising.
> Am I missing something?
Hi! Wouldn't using stochastic sampling ("AM3") with zero value for aa but a tiny
camera depth of field "aperture" so that you can keep its sample count minimal
between 3 and 5, the whole thing focused at the distance of your cylinder's
surface do the trick for you ? (I often ended uo using no aa and using only
aperture instead in the cases where I wanted some really photographic look
anyway. and it ended being a better trade off.
Otherwise, Le Forgeron's branch (HGPOVRAY38) has many additional camera types,
(among which a stereo one) does none suit your use?
